Just removed gearbox for the 4th time...
Started by JamesV6CDX, 11 May 2007, 16:43:41
... reseated the TC, so that it's definately fully home
bolted gearbox back on, and STILL the engine won't turn
I have run out of strength to do this again :(
Auto Addict
Wish I could help, really feel for you James :(
I like red cars
I really just don't know where to turn. I've tried leaving the TC on the driveplate, and mating up the box... engine won't turn that way
I've also tried engaging the TC in the box first, and then connecting to the driveplate..
Either way, when it's reassembled, the engine won't turn.
Markie is home at 5, and can help me with some manpower... but technically, I don't know what to try now.
Apart from a Jerry can and a match
To make matters worse... I need it for work at 6am tomorrow - else i WILL be in trouble, of the formal type  :'( :'( :'(
smoothomega
Wish i were closer James so i could lend a hand. I do remember changing an autobox a long while ago and suffering the same sort of problem in that by the time i had got the gearbox in place the TC had disingaged from the dogs and not allowing the bellhousing to meet the engine. It may also be worth measuring if you can the distance from the front of the TC to the face of the BH on both the old and new box to  see if they are the same if you have not already done it. Good luck and hope you sort it, i know how you must feel i have been there to many times to remember, Jez
Could the bellhousings be different? Like on a TD, when retro fitting an AR35, you need to use the AR25 bellhousing
this is an AR25 box replacing an AR35...
benjamind
Seems like are having a pig of a time , there is nothing worse than things constantly going wrong.
QuoteSeems like are having a pig of a time , there is nothing worse than things constantly going wrong.
It's all a learning curve.. the annoying thing is, I sucesfully did one of these on a 2.0 and it wasn't nearly this bad.
I'm just wondering, if, rather than me doing something wrong, it's actually the bellhousing! It's ten times harder doing jobs like this on your own, I hate to think what that box weighs!
nixoro
Maybe a silly suggestion but is the car in neutral or park.
When I changed the clutch on my 2.0 I couldnt turn the driveshaft doughnut until it was in neutral when trying to relocate the gearbox centre pin into the engine hope this makes sense.
QuoteMaybe a silly suggestion but is the car in neutral or park.
The prop coupling spins freely...
nixoro
Quote... reseated the TC, so that it's definately fully home
When you say the engine wont turn do you mean the clutch isn't engaging or the engine is not turning over.
Apologies for the silly question :-/ :-[
no clutch - it's an auto
the Engine is seized when trying to turn on the crank pulley
it can only be something jamming the drive plate.. but what - beats me
nixoro
Apologies I have manual on my mind :-[ :-[ :-[ :'( ;D
Ok
First off......is the box in neutral.....
1) Check ths spiggot bearing on the crank end is empty.....apply a small amount of grease to the inside face...
2) Check seating for torque converter on fluid pump shaft – Dimension "2" = 15 mm.
3) Check free movement of threaded bores (1) in torque converter.
4) Check centring journal (3) of torque converter for frictional rust and lubricate.
