Sump Plug
Started by andycuk71, 10 May 2007, 12:01:06
andycuk71
Trying to undo a sump plug with a star drive socket but it is not coming out just spinning help please
ians
Do you mean the bit is spinning in the plug, or that the plug is turning but not coming out?
andycuk71
Plug is turning but not coming out
ians
Sounds like something has lost its thread - hopefully the plug.
Can you grip it with something - mole grips or big pliers etc and encourage it downwards as you rotate it.  You need to find a way of pulling on it as you unscrew it.
QuotePlug is turning but not coming out
Hmmm, been there. In my case, sump was stripped :(
andycuk71
Any tips for getting it out??
andycuk71
Tried to pull down on it but can not get a good enough grip plug just spinning. >:( >:(
Am I going to have to take the sump pan off to sort this if so any idea how to drain oil????
I cut out my copper washer, so I could get under bolt (tractors still use older style plugs).  Did a little damage to sump, which I need to fix.
Dazzler
Are these sump plugs steal? If they are then have a smaller nut welded to the sump plug which will allow you to grip with moles and pull down whilst rotating the actual sump plug with a spanner. This i learnt on an Escort one day many moons ago.
If its an alloy then forget above :-[
ians
Can you get anything between the plug and the sump? Flat bladed screwdriever for example, to provide gentle encouragement.
Markie
and blast it with plus gas too.....may just be gunge and shavings stopping it from being released
andycuk71
Sorry to be thick but what is plus gas??
Markie
QuoteSorry to be thick but what is plus gas??
sorry its a brand - hard to find but dam good - basically a penetrating fluid. Probably wont help too much but at this stage worth a skoosh  ;)
I replaced my sump pan on my V6 a while back after I hit a slightly raised manhole (in Bolton  :( ) which ripped out the sump plug
For sump reason the steel sump plug screws into an aluminium insert that is pressed into the steel sump pan. All in all it cost me about £50 inc an oil change to sort it.
So you can't just go to the stores and book a tin out? I can :y  ;D
