cam cover gaskets
Started by benjamind, 14 May 2007, 13:14:37
benjamind
I have just ordered cam cover gaskets from VX do they come in a pack of 2? or do i need to order this item twice.? I hope you understand what i mean by this. Been given a price of £22.61 plus Vat does this seem correct for one or will that be for 2?.
Cheers Ben
Paul M
That'll be the price for one pack containing 2 gaskets. You need a pack for each side, hence 2 packs. There's a gasket over each camshaft, and 2 camshafts per bank hence 2 gaskets per bank.
It'll all become clear when you remove the covers. Don't forget the black sealant!
Darth Loo-knee
I paid around £55 for my Cam Cover Gaskets and "O" rings so I would say too that you only have one side.
benjamind
Thanks Guys i think i have got the hang of it now  :y
QuoteI have just ordered cam cover gaskets from VX do they come in a pack of 2? or do i need to order this item twice.? I hope you understand what i mean by this. Been given a price of £22.61 plus Vat does this seem correct for one or will that be for 2?.
Cheers Ben
Ben,
There will be 4 gaskets - 2 per side. Also there will be 16 O rings = 8 per camcover.
While you're getting some bits in, try and get a couple of tins of carb-cleaner, so we can do a throttle body clean and breather clean.
We may as well do the job properly
See you in Manchester on the 21st  :y
benjamind
Cheers James
You have my numbers give me a bell anytime you can. I will have all the necessary bits n bobs not a problem. Did you manage to complete the gearbox??
QuoteCheers James
Aye.. the Elite gearbox issue has now been identified, and (temporarily) resolved!
I say temporily, because I need to source an AR35 (stronger) gearbox.. but essentially, we got to the bottom of it!
Markjay
As said, the cam covers gasket are 2 per pack, so one pack per side... total 2 packs.
The O-rings are supplied in 10-packs, so you will need one full pack plus 6 from another pack... total 16 individual O-rings.
Alas, no more Omegas....
