Original Stereo
Started by donna-marie, 15 May 2007, 11:37:34
donna-marie
Looking out for an original stereo for 2.5cd and a replacement bonnet handle (snapped and need to replace)
Any body help and advise where i can get hold of either ;D
QuoteLooking out for an original stereo for 2.5cd and a replacement bonnet handle (snapped and need to replace)
Facelift or prefacelift? Facelift are double din, prefacelift are single din
ians
DM,
You could try a local breakers for the bonnet handle.  I suspect they won't have the radio though.
You could also try a few of these
http://www.yell.com/ucs/UcsSearchAction.do?scrambleSeed=91338193&keywords=vauxhall+breakers&companyName=&location=&search=SEARCH&M=0
This might help as well
http://www.1stchoice.co.uk/?gad=CNGNrrkCEgjlPvN-1pDnbxj-n7j_AyCh1p4R
Why do you need an original stereo?
Cheers
Ian
Danny
possibly ebay for the stereo
Or Timbuk....depending on model year.....
donna-marie
wanted original stereo to make it look nice (a girly thing) plus have fitted my own but stering volumes and station change don't work. May be get some one to look at might it be an extra connection. Plus cannot get a radio station to stay put. It has an ariel i think in the back window but doesnt work.
thanks for all your help
You can get adaptor boxes to allow the steering wheel controls to drive certain stereos but they're a bit pricey. TBH if you're happy with the factory one it's no bad thing to put one back in. Makes the car look totally standard so no-one will think of trying to nick it! Put a post in the parts wanted section and someone will be along. It's worth making sure you get the unlock codes for them, however!
In addition, the ignition switched and permanent live feeds to the stereo are often the wrong way round on the car wiring loom and this may well be why your radio is losing the station memories. Have a look behind the stereo and see if there is an adaptor loom which allows you to swap the two feeds over.
QuotePlus cannot get a radio station to stay put.
You need to swap the igniton and permananet live feeds over on aftermarket radio kit.....they often have bullet connectors to support this.
pfundu1
I know where two original strero's are and the other item is aswell. Give me a call on 07811169418, i live in Newcastle upon Tyne.
