Pages: [1] 2 3  All   Go Down
Author Topic: Finally read gearbox ecu - advice needed  (Read 6763 times)
JONNYWAKEY
  • Bilsthorpe Nottinghamshire
« on: 09 May 2007, 17:24:34 »
Guys
Here I am again wanting your expert opinion on my omega!
Finally read gearbox ecu and found the following:-
P0727 - Engine speed input circuit, no signal ? is this Crank Sensor?
P1781 - Can databus - ecm act torque signal malfunc detected
P1740 - AT Torque control signal malfunction.
Cleared these stored codes and then read engine ecu,
Presented with these codes:-
P0340 - Camshaft sensor - changed in Sept 2006?
P1700 - MIL request
Does this mean I need a new gearbox as car drives okay ?
Will a recon one do or is this repairable?
Cheers
JOnny
Re: Finally read gearbox ecu - advice needed
« Reply #1 on: 09 May 2007, 17:33:23 »
As said before.....I still think cam sensor......or associated wiring......the codes are sudgesting the same
JONNYWAKEY
« Reply #2 on: 09 May 2007, 17:35:55 »
Mark
Thanks for getting back to me, could this still be the cam sensor even though it was only changed in sept '06?
I thought the Gearbox ECU codes were indicating a more serious problem?
Cheers
JOnny
« Reply #3 on: 09 May 2007, 17:38:24 »
Taxi driver is replying....lets see what he thinks...
Taxi_Driver
« Reply #4 on: 09 May 2007, 17:38:25 »
Does it sruggle to start sometimes? when hot?
If so change the cam sensor again!
If not they could be old codes......so i would just clear them first to see if any come back.
They look suspiciously just like the codes i was getting when it was my cam sensor.
I still get P1700.......but ignore it.....i carnt read the g/b ecu anymore with cheapo tech2 since it was upgraded to latest version.....so dont know what mine is complaining about.....but imo unless theres summat wrong with the g/b i would leave alone
Taxi_Driver
« Reply #5 on: 09 May 2007, 17:39:49 »
Mark beat me to it! lol.....but then i got distracted with a phone call.....i know excuses  ;D
JONNYWAKEY
« Reply #6 on: 09 May 2007, 17:46:05 »
Here we are again Taxi !
You are right, I do have trouble starting, if car takes more that 2 turnovers to start, EML comes on and sports mode is prohibited (Limp).
If I then turn off,  wait for lights to go out, car starts straight away and EML goes off!
As I am an Aerospace Avionics engineer, I may try and chase the wiring on from the CAm sensor and replace the wiring loom and sensor at the same time.
Does anyone know where the wiring runs to ?
Cheers again
JOnny
Taxi_Driver
« Reply #7 on: 09 May 2007, 18:52:46 »
Cheers again
JOnny
Yep defo just like mine used to do......new cam sensor fixed mine and like AA's i believe
If youve already changed it back in Sept06, I assume its been ok for a while since?
If not, did you change it yourself? Just i mention this, as a lying stealer told me they had changed it  >:(
I would assume the wires goto the ecu......if your planning on replacing them.....which i would only do after changing the sensor again.....i would think its probably easier to run new wires....and cut the old ones off....as i suspect the wires will disapear into a big loom and be near on impossible to seperate them.
« Last Edit: 09 May 2007, 18:56:07 by Taxi_Driver »
JONNYWAKEY
« Reply #8 on: 09 May 2007, 19:00:55 »
Thanks Taxi !
I may well try a new sensor, my father in law owns the garage that changed it in Sept so i do trust that it was done however these things can fail quickly.
With regards to the wiring, i wouldn't even attempt to break into the wiring loom, thats asking for trouble, I will look at the schematic wiring diag on a little bit of software that I have - mentioning no names !
Other than that I will buzz out from the sensor plug end and back to main ecu to trace wiring.
Thanks for the advice again.
Cheers
JOnny
« Reply #9 on: 09 May 2007, 19:24:14 »
Cam sensor, as we said earlier, and the 0340 proves it ;)
« Reply #10 on: 09 May 2007, 20:45:24 »
The sensor should be covered under warranty......and its a piece of piss to change....
« Reply #11 on: 09 May 2007, 21:10:52 »
Was if definatively the CAM sensor changed last time, not CRANK sensor?
Taxi_Driver
« Reply #12 on: 09 May 2007, 21:19:20 »
As long as you dont follow vx's way off doing the job!  :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #13 on: 09 May 2007, 21:28:35 »
Cam sensor.
I like red cars
Taxi_Driver
« Reply #14 on: 09 May 2007, 21:40:22 »
Cam sensor.
Oh your still about then AA?  ;D Was begginging to wonder as i havent seen a post in a while  ::)
Too much golf and afternoon naps i suspect  ;D ;)
Pages: [1] 2 3  All   Go Up
Page created in 0.008 seconds with 16 queries.
