Engine stop
Started by donna-marie, 17 May 2007, 13:32:31
donna-marie
out in car yesterday car stopped, left for 1-2 mins then started up fine. Same again today. Help me please. Is it a hospital job. :'(
Can you read the ECU fault codes.....I suspect crank sensor....which is an easy fix.
donna-marie
Cheers for that, any easy way to find out the code?
Yes, you need to short out pin 4 to pin 6 of the diag connector in the fuse box below the steering wheel with a paper clip or similar.
Read here for details on how to....
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
I suspect a code 19....
donna-marie
Cheers darling, now a happy bunny been told £15
Using the above technique....its free :y
Does sound a bit crank sensor, but do as M_DTM says, and do the paperclip test.  If you get a 19, change the crank sensor asap.  They have a habit of really letting you down in inconvenient places....
Markjay
QuoteDoes sound a bit crank sensor, but do as M_DTM says, and do the paperclip test.  If you get a 19, change the crank sensor asap.  They have a habit of really letting you down in inconvenient places....
...such as Co-op car parks...  ;D
Alas, no more Omegas....
STMO123
Quote...or France ;D ;D ;D ;D ;D ;D
Want those post counts removed again?
;D
STMO123
;D
:-X
;D
:-X
Actually, I think I am nearly over that incident of breaking down in France.  It was nearly 2 yrs ago ::)
STMO123
If only it were just a sensor on your tractor ;D ;D      :-X
QuoteIf only it were just a sensor on your tractor ;D ;D      :-X
It may be? Who knows....
