RUST ALONG TOP OF DOOR UNDER WINDOW
Started by magnaman, 17 May 2007, 21:47:43
magnaman
HI ALL HOW EASY IS IT TO TAKE OFF THE SEAL ON OUTSIDE OF CAR WHERE THE WINDOW GOES DOWN TO FIX RUST CAN IT BE DONE FROM OUTSIDE OR DO I HAVE TO REMOVE INSIDE DOOR CARD AND WINDOW
QuoteHI ALL HOW EASY IS IT TO TAKE OFF THE SEAL ON OUTSIDE OF CAR WHERE THE WINDOW GOES DOWN TO FIX RUST CAN IT BE DONE FROM OUTSIDE OR DO I HAVE TO REMOVE INSIDE DOOR CARD AND WINDOW
They appear to rust from inside out. So if its bad, source replacement door.
I have been 'playing' with this ailment a bit recently.....
I have come to the conclusion that its possibly caused by
a) Grit getting trapped between the seal and paint
b) damage to the paint during assembly.
I have managed to remove the seal by starting at the B post end and easing it out and then working along lifting a small bit at a time in order to try to keep the seal straight.
QuoteI have been 'playing' with this ailment a bit recently.....
Wanna practice on a NSR MV6 door ::)
Paul M
The rust on these cars is a proper pisser, mine has the classic spot on the bottom centre of the two front doors and it's starting to get quite bad. I've been tempted to get it sorted but not sure if it's worth the effort as it seems guaranteed to come back soon enough.
Been on the lookout for replacement doors within driving distance but nothing in the correct colour :(
Markie
QuoteThe rust on these cars is a proper pisser, mine has the classic spot on the bottom centre of the two front doors and it's starting to get quite bad. I've been tempted to get it sorted but not sure if it's worth the effort as it seems guaranteed to come back soon enough.
same. mines is frankly disgusting now. And its on all 4 doors. :-[
Paul M
That's pretty disappointing considering yours is two years younger than mine. I don't hold out much hope of finding a scrapped Omega with rust-free doors at all TBH. I think I'll just have to try repairing them, even if it is only a temporary fix. Not a job I've any experience of, seeing that all of my previous cars combined have less rust than this Omega ::) It really is the achilles heel of these cars.
I wonder if door skins are available.
