Author Topic: Driver side heater wont get hot please help  (Read 1896 times)
wheelchairkid
  • Northampton
« on: 21 May 2007, 13:19:37 »
Hi to all
           I have got a 2001 X reg Omega Elite, 2.6 auto estate. it has the digital climate control, but no matter what I do, I can not get warm or hot air to com out of the drivers side vents. it gets nice and hot in the passengers side and the back.  Have any of you got any Idears on what it could be?
                                   Yours
                                      Jason :'(
It was not me, I did not touch it, I was not there!
    • E250 Est / Elroq
Re: Driver side heater wont get hot please help
« Reply #1 on: 21 May 2007, 13:21:06 »
Have you tried the reset servo procedure, press and hold off and auto for a few seconds, you know its worked, you hear the motors going.
After that, I dunno. loose pipe or something?
« Last Edit: 21 May 2007, 13:21:40 by jimbob »
« Reply #2 on: 21 May 2007, 13:38:34 »
...if after that it does not work then its onto the temperature control servo on the drivers side of the heater assembly in the drivers footwell
wheelchairkid
  • Northampton
« Reply #3 on: 21 May 2007, 14:25:48 »
Hi tried resetting the servo`s, no good, but I then looked in the drivers footwell, and found a thin black plasitc rod with two holes in the end, not conected to any thing, but when I pul the black rod down I get hot air, so all I need to know is what should it conect to, and what does it look like?
                                        Yours
                                               Jason :y
delroy_omega
« Reply #4 on: 22 May 2007, 16:21:59 »
Had the same problem on my facelift omega. Check this link: http://www.cavweb-forums.co.uk/showthread.php?t=118890 :y
