Author Topic: spanner light + no power (now with codes)  (Read 2551 times)
« on: 25 May 2007, 18:44:37 »
You may remember my 2.2 Omega had a problem yesterday, starts fine, idle too high at 1,300 RPM, spanner light was on, pressed the gas pedal nothing happened .
Got the codes (thanks to Jaime for reading them even when he had family around  :y)
P1550 - Electronic Throttle Control Motor
P1500 - Electronic Throttle Control Motor Failure
P1525 - Limp Home Position Error
Once warm, the enging was fine. Problem has not come back, even after another cold start.
Throttle body and breathers cleaned last summer....
Craig_R
  • Watford
Re: spanner light + no power (now with codes)
« Reply #1 on: 25 May 2007, 18:48:15 »
I hope it was just a clitch on your throttle body tunnie as they cost a fortune the DBW ones i have seen them on ebay for about 230 quid but i did see one once for 20 quid.
Fingers crossed for you tunnie it will befine from now on  :y
Craig
Mod's
[To be Fitted]Reverse Sensors
« Reply #2 on: 25 May 2007, 18:50:36 »
Craig
Cheers m8, Jaime was saying the same....
Maybe its a good excuse to swap it for a V6  ::)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #3 on: 25 May 2007, 20:13:25 »
Before you jump to too many conclusions, I would clean up the electrical contacts to the throttle control motor, with a good contact cleaner.
I seem to remember MarksDTM saying he's never know one to fail yet, of course there could always be a first time, but fingers crossed.
It won't do any harm to clean up the throttle body and breathers again, it's not a difficult job.
« Last Edit: 25 May 2007, 20:15:28 by Auto_Addict »
I like red cars
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #4 on: 25 May 2007, 21:30:27 »
Mark also suggests cleaning the MAF contacts with computer foam clean :-?
Mine ran excessive rpm last year Tunnie after I'd cleaned the breathers, turned out to be nothing more sinister than a sticking butterfly.
« Reply #5 on: 25 May 2007, 21:37:59 »
Got sneaky feeling thats that might be it...
First job when i get back after the trip this weekend is to give the Omega some love and attention  :)
Bernard
  • Bimingham-Near NEC
« Reply #6 on: 26 May 2007, 02:39:06 »
Not Adviseable to to clean with Computer foam clean as this is Water based ! Far better to use Electrical Contact cleaner. :y
Nothing gives you a oooooh like a good old Vauxhall.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #7 on: 26 May 2007, 08:33:45 »
IIRC tunnie, have you cleaned out that back breather pipe at the back of the camcover, the one you couldn't get off?
I like red cars
« Reply #8 on: 26 May 2007, 09:36:16 »
As I originaly said....sticking throttle.....its been sat dry for a few weeks, stuck shut and the ECU stuck it in de-stick (max thrutch to the actuating motor) and then limp mode....
Page created in 0.023 seconds with 20 queries.
