Author Topic: CAMS  (Read 2051 times)
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
CAMS
« on: 22 June 2007, 18:11:15 »
Is it poss to fit 3.2cams into a 2.5 engine seeing as you can fit 3.0 into 2.5 v6's.just mulling ideas over in my brain cell, ;D ;D
Jaguar XJ6
Admin
Re: CAMS
« Reply #1 on: 22 June 2007, 19:18:47 »
No...
3.2 cams won't even fit in a 3.0 engine.
The 2.5 and 3.0 are basically the same lump with different sized heads and a few other bits and bobs.  ::)
3.2 is quite different...
You want a set of 3.0 cams. Expect to pay £100+ for a set, and yes, you do need all 4!
The Administrator.
Re: CAMS
« Reply #2 on: 22 June 2007, 19:25:36 »
No...
Yes they will they are the same head design.....
Not sure if they are the same cam shafts.
There is not a great deal of difference between the 3.0 and 3.2 engine mechnics...
Martin_1962
Re: CAMS
« Reply #3 on: 22 June 2007, 19:59:56 »
So what do you fit in a 2.6?
Admin
Re: CAMS
« Reply #4 on: 22 June 2007, 20:35:18 »
No...
Hmmm...
When I looked at this I found the heads were actually slightly different with altered profiling on the cams.... but I will defer to your greater knowledge.  :)
The Administrator.
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: CAMS
« Reply #5 on: 22 June 2007, 22:28:47 »
rumour has it that EPC shows the inlet cam is the same for 3.0 and 3.2's - but the exhaust cam has a different part number for the 3.2 ...  ::)
« Last Edit: 22 June 2007, 22:30:49 by sounds2k »
Re: CAMS
« Reply #6 on: 22 June 2007, 22:39:13 »
so will 3.2 cams fit 2.6?
ffcgary1
  • Mitcham,Surrey.
Re: CAMS
« Reply #7 on: 22 June 2007, 23:30:57 »
Me thinks that this conversion needs further investigation.How about 3.2 inlet,and 3.0 ex in a 2.5 motor. :D
Jaguar XJ6
