Author Topic: Pollen filter  (Read 2568 times)
charlottesdad
  • Luton Beds UK
Pollen filter
« on: 05 July 2007, 23:57:31 »
I have seen it somewhere in the forum about a carbon pollen filter when climate control is fitted. I have asked my local Vauxhall dealer, parts dept, about this and they tell me there is only one filter which is a paper type. The guy who looks after my car, he is a mechanic at the same dealership, agrees with the parts dept. that there is only one pollen filter. I am confused. Can anybody tell me the part number for the carbon filter. Thanks Alan
Tiefer
  • Spain
    • 2.6 Elegance
Re: Pollen filter
« Reply #1 on: 06 July 2007, 01:28:31 »
Hi,
I bought it yesterday (in Spain, but if it's available here, it must be there too).
GM 9162646
Cat. 18 08 618
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: Pollen filter
« Reply #2 on: 06 July 2007, 08:20:47 »
it depends on if your omega is a facelift model or not. If not then it's a white coloured filter, if facelift they use an activated charcoal (grey coloured) one, this is required if you use the automatic air recirculation feature. If you don't then you can get away with the (cheaper) non-activated charcoal one.916
cheapo (older) filter is P/N 93182438 (or maybe 90510338)
activated charcoal type is P/N 93165208 (which supersedes 9162646)
« Last Edit: 06 July 2007, 08:27:17 by sounds2k »
Re: Pollen filter
« Reply #3 on: 06 July 2007, 08:23:24 »
Why do dealers do this.....it really does not fill you full of confidence...
Ok
Standard Pollen filter 93182438
Carbon filter 93165208
The carbon filter is primarily used on the facelift cars as its required to get good operation from the pollution sensor but, can be retrofitted to the earlier models (as it does help with some smells)
So next time you go into the dealer, give them the info and lean over the counter, look them directly in the eye whilst smiling politely and whisper gently.....'muppet'
    • E250 Est / Elroq
Re: Pollen filter
« Reply #4 on: 06 July 2007, 08:33:21 »
Ive replaced both ours, should be 1 of each, but anyone who has smelt my ar53 knows why I have carbon types in both  ::)
Do get looked at daft asking for that one for some reason.
Re: Pollen filter
« Reply #5 on: 06 July 2007, 08:53:32 »
Its not carbon for climate cars, but for facelifts (which are all climate). Prefacelift climates are supposed to have the normal white one, but can run the carbon one. The carbon pollen filter, as well as blocking pollen etc, does seem to reduce fume smell in cabin.
So summary:
If you have a prefacelift (climate or not)
93182438 £12+VAT retail, coloured white
or
93165208 £15+VAT retail, coloured grey
If you have a facelift (all are climate)
charlottesdad
  • Luton Beds UK
Re: Pollen filter
« Reply #6 on: 06 July 2007, 09:06:24 »
Thanks very much. My car is the facelift model, I have just rung my local dealer and would you beleive it they don't stock that part number filter. I explained what it was and the reply was, " we always supply the white coloured filter". Now going to ring around motor factors to see if they are more helpful. Alan ::) ::)
Re: Pollen filter
« Reply #7 on: 06 July 2007, 09:09:01 »
I believe its dealer only - some of the factors show a standard white one for facelifts as well.
Luton is Evans Halshaw - ask them to check their other branches, and get it in, or order it...
Markjay
  • London
Re: Pollen filter
« Reply #8 on: 06 July 2007, 23:41:08 »
Ok
Hehe, the parts manager at my Vx dealer also said the same 'only one filter sir', until I showed him the charcoal type in the flesh and told him that all facelift needed it, he seems genuinely concerned and said he will talk to the service guys... and since then they actually stock both types!
And. another Vx dealership fitted the non-charcoal one on my facelift during a service - easily soppted based on the P/N in the bill.
« Last Edit: 06 July 2007, 23:49:17 by markjay »
Alas, no more Omegas....
Markjay
  • London
Re: Pollen filter
« Reply #9 on: 06 July 2007, 23:43:22 »
They do exist! Print this out and take it to your Vx dealer...:
« Last Edit: 06 July 2007, 23:44:10 by markjay »
Markjay
  • London
Re: Pollen filter
« Reply #10 on: 06 July 2007, 23:48:12 »
Also - there is a theory (which I made up... ) that fitting the old non-charcoal filter on a facelift will confuse the air quality sensor which in turn will cause erratic operation of the (too-sophisticated-for-it-own-good) Climate Control system...
Page created in 0.224 seconds with 20 queries.
