Author Topic: Windscreen fitted incorrectly?  (Read 6118 times)
BazMV6
  • Silverstone
« on: 11 July 2007, 14:48:25 »
Hello again,
I had a new windscreen fitted on Monday in preparation for the MOT (which it just passed BTW - one new tyre and a handbrake adjustment).
But I'm not sure they've fitted it correctly.  I'm convinced that on the old one the rubber (neoprene?) was almost flush with the screen all round.  But it now has an obvious slot down each side.  This is all the more obvious since the slot disappears at the top corners, and the glass fits snugly into it along the top.  Makes me think the glass ought to fit into the slot all the way around??!?
Can anyone do a quick comparison for me?  I'll post some pics tonight if that's any help...
Cheers,
Baz.
This space left blank for your own message...
megaomega123
Re: Windscreen fitted incorrectly?
« Reply #1 on: 11 July 2007, 14:52:20 »
Ditto. Exact same thing. Looks like the glass should be in the outer slot where the rubber stands proud from the glass. I just thought it was normal, but it doesn't look as good as it did before replacement.
Grumpy
  • Manchester
« Reply #2 on: 11 July 2007, 15:25:19 »
I think you'll find that it is fitted correctly. These screens are bonded into
place by folk who do this for a living every day of their lives.  :)
Just checked mine for you, which hasn't been replaced, and it's the same
as yours.  :y
« Reply #3 on: 11 July 2007, 15:43:00 »
Yes, they are fitted by people who do them every day....just like mechanics who fix cars every day and tyre fitters who fit tyres everyday.
Interestingly, the screen has a set of plastic sections which fit onto the edge of the glass, its into these that the rubber weather strip fits......sometimes the plastic gets damaged on screen removal and do you think they bother fitting new ones (which they should do!)
I will check mine this PM to see if I also have a gap but, I dont think I do.
BazMV6
  • Silverstone
« Reply #4 on: 11 July 2007, 16:05:01 »
Thanks for the comments so far - at least I'm not alone...
You would think the "experts" would be able to get it right - but that's why I asked here!   ;)
Kaycee
  • Doncaster
« Reply #5 on: 11 July 2007, 16:45:18 »
Just had mine replaced yesterday at RAC Windscreens i too have a raised gasket at both top corners i have just been back today to complain and they said its a common fault i said 'come on' yu having me on im not accepting it' at that they said they would order GM gaskets and refit it for me.
robert
There is a tide in the affairs of man if taken at the flood will lead on to greater things
old cruiser
  • Slough
« Reply #6 on: 11 July 2007, 19:29:06 »
Well done Robert, that's exactly the thing to do REJECT it as they are never right after new glass because they don't use the original size gaskets and only GM ones will do, what is it with RAC windscreens , only ever do half a job, always had to go back and complain whenever I've used them!
cheers Pete
« Reply #7 on: 11 July 2007, 20:42:54 »
You're not wrong there. SWMBO's MX-5 had one not long ago. All plastic covers on the scuttle fixing screws and the wiper nuts broken off, and stuck back in with a dob of Sikaflex.  >:(
I can understand one plastic cap breaking on a job if they've got brittle over the years but to knacker them all you've got to be a total gibbon or taking no care whatsoever - or both.
« Reply #8 on: 11 July 2007, 21:43:06 »
This evening I have checked 4 Omega windscreens.....2 have been replaced adn two are original.
All 4 had a good seal to the body work.
All 4 have a 4-5mm space down the two sides between the seal and glass, this space is created by the plastic trim piece I mentioned earlier.
All 4 sealed fully onto the top of the screen.
BazMV6
  • Silverstone
« Reply #9 on: 12 July 2007, 09:29:03 »
If I can manage it, here are the photos. Sorry they are a bit blurry - I think the camera focussed on the reflections. I wish I had "before" images too...
Robert - mine was fitted by RAC Windscreens too.  I think I'll pop along to see what they say at lunchtime - though I'm not optimistic, given that I have no evidence, and so many others seem to be the same...
Baz.
« Reply #10 on: 12 July 2007, 09:56:35 »
Thats correct fitment.
old cruiser
  • Slough
« Reply #11 on: 12 July 2007, 14:21:11 »
I've just edited your photo with 2x red arrows, is that a gap there between these arrows if so, shouldn't be
http://s149.photobucket.com/albums/s74/tweddles/?action=view&current=windsreen-1.jpg
BazMV6
  • Silverstone
« Reply #12 on: 12 July 2007, 15:12:56 »
No - no gap there cruiser.  The dark line is just the reflection of the rubber I think.  It's just at the top corners where it looks as though the glass rides out of the slot it sits in quite nicely along the top edge.
I scoured our car park at lunchtime, and couldn't find a single Meega to compare it with!   :(
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #13 on: 12 July 2007, 18:53:29 »
Yeah! mines the same, original GM screen....  I think the furrow is to prevent the water from blowing down the side windows when driving, directs it into the scuttle or over the roof...
DC
« Reply #14 on: 12 July 2007, 18:55:09 »
The gullies are to help prevent water coming over A post...
