Author Topic: Misty  (Read 1687 times)
omegalyn
Misty
« on: 20 July 2007, 11:15:34 »
Hi there,
I have noticed lately that the windscreen mists up more than usual, this weather is not helping I know but it gets worse then I put the fans on full to demist for about a minuet then starts to clear very slowly. I have cleaned out the scuttle drain, and I don’t think that I am loosing any coolant. I have been doing other jobs, e.g. cam cover gasket to stop a leak at the back, but now I have a leak at the front, Bo#*@cks. Been out in this rain so long I think I’m growing fins.
Thanks
Lyn.
Re: Misty
« Reply #1 on: 20 July 2007, 11:24:49 »
2 other things to check re misting - check pollen filter is dry, and check the cubby hole in boot, driver side, is clear...
omegalyn
Re: Misty
« Reply #2 on: 20 July 2007, 11:27:44 »
whats that then?
Re: Misty
« Reply #3 on: 20 July 2007, 11:39:40 »
whats that then?
The pull down flap, where earlier cars have their CD player - the bit you pull down to get to osr light cluster...
SPS
Re: Misty
« Reply #4 on: 20 July 2007, 19:29:58 »
Hi there,
Thanks
Lyn.
Hi
Mine is blocked and I am getting bucketsful of water in the passengers footwell (front and back) I have tried to reach in but can't ge to the bottom - how did you clean it out?
Thanks
Re: Misty
« Reply #5 on: 20 July 2007, 19:36:21 »
Hi there,
Thanks
Lyn.
Another thing to check is make sure you have't got the recirculation switch pressed ;)
« Last Edit: 20 July 2007, 19:36:49 by Elite_Pete »
Re: Misty
« Reply #6 on: 20 July 2007, 19:39:23 »
Hi there,
Thanks
Lyn.
Hi
Thanks
SPS try this :y
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
gizza
  • baildon essex
Re: Misty
« Reply #7 on: 21 July 2007, 09:56:39 »
Hi there,
Thanks
Lyn.
Hi
Thanks
i used a wet and dry vacum cleaner then pushed one side of the plug out at the bottom of the of the cavity and not had any problems since, i used a lond flat head screwdriver and just gave it a bit of force
