Author Topic: leaking sunroof  (Read 2179 times)
bigup316
  • oxfordshire
leaking sunroof
« on: 20 July 2007, 21:08:52 »
sunroof is leaking from the corner is there a seal i can check does anyone know a tempory fix just to stop water feels like i am having a shower in the car not a good start to the day
    • E250 Est / Elroq
Re: leaking sunroof
« Reply #1 on: 20 July 2007, 21:15:32 »
Gaffer tape?
Re: leaking sunroof
« Reply #2 on: 20 July 2007, 21:18:41 »
the tray around the opening should have drains - check these aren't blocked.
BrianH
  • Bexley,Kent
Re: leaking sunroof
« Reply #3 on: 22 July 2007, 21:41:38 »
Check seal around glass mine leaked when about 6 months old Dealer changed glass panel under warenty after first changing tray which only ended up giving me an annoying rattle plus original leak.
After cosy chat in car with tester and use of hosepipe making sure he was sitting under leak he agreed it was actual glass panel leaking.
Possible use of windscreen seal might be worth a try to start off as its fairly cheap and would easily eliminate glass.
Brian    :y
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
Re: leaking sunroof
« Reply #4 on: 22 July 2007, 22:30:17 »
Top tip coming up - mine was doing the same when I first purchased it and was told by a neighbour that the seal on most sometimes go hard and start to leak. He suggested a liberal dose of washing up liquid in hot water on a dishwashing brush and scrub the seal of all algea and basically - refluff it up.  Worked a treat first time - I do this every Autumn as I struggle sometimes to be able to open the bloody thing every spring . Don't anymore :D :y
