Author Topic: Steering Column Removal  (Read 1867 times)
Craig_R
  • Watford
« on: 01 August 2007, 20:41:35 »
Was having a look at the Steering Column bolts to see if they were tight and was stumpted when the left hand side had no nut just some funny round thing. The Right Hand Side Does have a normal Nut
Is this Normal ?
Lefthand Side
Righthand Side
Mod's
[To be Fitted]Reverse Sensors
Craig_R
  • Watford
Re: Steering Column Removal
« Reply #1 on: 02 August 2007, 09:15:10 »
Anyone ?
Someone must of removed a steering column or have a haynes manual
Thanks
Craig
Mod's
Matchless
  • Nottingham
    • A white van
« Reply #2 on: 02 August 2007, 09:28:17 »
Thats correct, the left hand bolt has a shear head as a security measure. Centre punch then drill off the head, use a large drill, 10mm say, and the head should come off without damaging the threads.
Have you spotted the other mounting bolt about half way down the column?
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 02 August 2007, 09:31:08 »
This http://www.omegaowners.com/forum/YaBB.pl?num=1163633862 might help, sorry its all words, I didnt get around to adding pics.
Craig_R
  • Watford
« Reply #4 on: 02 August 2007, 09:37:39 »
I have thanks Matchless
I was wanting to lossen the bolts off and try something i have read something on the darkside that mark wrote.
Interestingly TIS actualy states a remedy for this condition....
Complaint - Noises and Vibrations, sqeeking noises under cold and wet weather conditions.
Cause - Tension on steering column
Solution - relieve the stress on the steering column by loosening and re-fastening the tube attachment screws.
So basicaly what Vauxhall are saying is remove your steering column shroud and open the fuse box cover, slacken off the securing bolts that hold the main column outer tube (normaly two at the top - one is normaly a sheer type so may not be able to slacken and one at the bottom of the tube). Then rotate the steering from stop to stop twice and re-fasten.
Mod's
Craig_R
  • Watford
« Reply #5 on: 02 August 2007, 21:06:45 »
Thanks Matchless for the How 2
So is there a nut under that round shear head thingy ?
Craig
Mod's
Matchless
  • Nottingham
    • A white van
« Reply #6 on: 03 August 2007, 09:42:57 »
Stud on the RH
Captive nut on LH
Captive nut on middle
You will need a replacement bolt and can order a shear bolt from Vx but a 8.8 quality hex head will do....just use the washer off the old bolt and enlarge the hole through it slightly with a file.
(If a tea leaf has gained sufficient access to be removing your steering column then the absence of a shear bolt is a bit irrelevant)
