Author Topic: Multimrams!!  (Read 1677 times)
omegabeast
Multimrams!!
« on: 20 August 2007, 10:29:51 »
Hi all,
Sorry to start another thread but really need some help with this.
My multiram isnt working , neither the one for the low revs or the one for the 4k revs.
What things do i need to check to get it working again.
Matt  :)
IrmscherKris
  • Manchester
  • banned due to bad trader references
Re: Multimrams!!
« Reply #1 on: 20 August 2007, 10:34:51 »
Check for un-connected vac pipes broken or split ones..
Make sure the solenoid's are plugged in............  :y
omegabeast
Re: Multimrams!!
« Reply #2 on: 20 August 2007, 10:36:59 »
The solenoids are plugged in. Been told it might be an airleak?
Cant find one though so will have to have a good look at it
Matt
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Multimrams!!
« Reply #3 on: 20 August 2007, 10:42:41 »
Matt
Matt take a look at this thread
http://www.omegaowners.com/forum/YaBB.pl?num=1187436342
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Multimrams!!
« Reply #4 on: 20 August 2007, 10:48:53 »
All i am trying to say is if you try what Neil did connecting the two Vac Tank pipes together maybe your Multi Rams will work like his did. If not it is something else. But putting the pipes together is not a fix as you need the Vac Tank.
omegabeast
Re: Multimrams!!
« Reply #5 on: 20 August 2007, 12:20:43 »
Hi,
Tried it just and the 4k one worked , but not as quick as yours did looknee , but the low revs one didnt work at all
I was thinking it was maybe the vac tank , but then the low revs one would have worked then surely.
Matt
« Last Edit: 20 August 2007, 12:22:41 by omegabeast »
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Multimrams!!
« Reply #6 on: 20 August 2007, 13:02:47 »
Hi,
Matt
Did you get the diagram that I told you about so you can make sure that all the little vac pipes are in the correct positions? I will e-mail it to you, just print it out then follow the diagram :y
