Author Topic: Brake discs  (Read 3853 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Brake discs
« on: 05 September 2007, 18:37:45 »
Right I decided to try my TC at a different dealer (Banbury) I had intended to do the oil etc but on my way there my brake light warning (pads) came on  :( so no problem I decided to do the brake pads and get them instead. I asked if it was ok to use the tc and this was no problem at all unlike at the other dealer I tried the other day  >:( pads and the wear indicators £31.11 or thereabouts the indicators were more than the pads  :-? I had intended to change the pads this afternoon took the offside wheel off and found the pad not as excessiley worn as I was expecting but the indicator had broken. I dropped the caliper off to remove the old pads and on inspection I have found that the inner pad has a step worn in it on the outer edge, this matches a raised ridge on the disc so disc fubar  :( the other side of the disc is not too bad it has a slight lip on it. The nearside disc looks fairly good althought it has a lip. I know they will both require changing. Question is where would you suggest I get the discs from
Halfords £56ish with tc local carpart place about £40 or genuine vx with tc (anyone know how much ). Suggestions please  :y
Re: Brake discs
« Reply #1 on: 05 September 2007, 18:39:53 »
VX TC - £69 + VAT which includes the pads.
The pattern ones on my MV6 are rubbish.  I'd stick to genuine if you can.
LFF64
  • HADDENHAM BUCKS
Re: Brake discs
« Reply #2 on: 05 September 2007, 18:43:02 »
What about just discs I brought the pads yesterday from vx
LFF64
  • HADDENHAM BUCKS
Re: Brake discs
« Reply #3 on: 05 September 2007, 18:52:52 »
Oh and if any one spots a gorilla walking around with a wheel brace I could have done with him earlier  >:( I had to stand and bounce (and I am not that light) :-[   on the wheel brace to undo the nuts they were stupidly tight  >:(
Re: Brake discs
« Reply #4 on: 05 September 2007, 18:58:44 »
Fairly certain on TC only available as a disc/pad set (doesn't include sensors though  :-/)...
You could ring Banbury 01295 755400 and ask if they will do discs only, and how much. Quote your TC number...
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Brake discs
« Reply #5 on: 05 September 2007, 19:01:30 »
If you ain't fitted the new pads yet how about asking them to swap for a disc/pad set?
TuBy's new whipping boy.
Re: Brake discs
« Reply #6 on: 05 September 2007, 19:04:05 »
Just put 'em in a drawer for another time.
LFF64
  • HADDENHAM BUCKS
Re: Brake discs
« Reply #7 on: 05 September 2007, 19:04:44 »
Thanks TB I will do that. I will take a pic of the wear on the old disc when I get it off it is a bit odd the way it has worn
Re: Brake discs
« Reply #8 on: 05 September 2007, 19:17:05 »
Similar, I suspect, to Tunnies 2.2 and my tractor...
Re: Brake discs
« Reply #9 on: 05 September 2007, 20:26:40 »
gen vx discs made a big, big BIG difference on mine...
If you change the discs, bleed and flush the fluid too!  :y
LFF64
  • HADDENHAM BUCKS
Re: Brake discs
« Reply #10 on: 05 September 2007, 20:45:27 »
Yes I was hoping they may be able to do something as they have not been fitted yet I mean they are going to be the same pads arent they after all.I had thought about doing the fluid too but I think it may have been done recently by the previuos owner, To tell the truth the pads are not even that bad they are just over half gone and they are genuine ones too. What I did mean to ask is on the new pads there was a direction arrow I am assuming this points in wheel direction when fitted  :question
hotel21
  • The Kingdom of Fife
Re: Brake discs
« Reply #11 on: 05 September 2007, 20:48:37 »
IME, its the wheel rotation direction.
Markjay
  • London
Re: Brake discs
« Reply #12 on: 05 September 2007, 20:59:54 »
Yes, and also the two pads with the arrow go on the inner side, the ones without the arrow goes on the outer side.
Having said that, I apparently drove 25k miles on pads installed by Vx with the arrows pointing in the wrong direction (as I discovered when I took them out to replace them) , and did not notice any problems...
Alas, no more Omegas....
Re: Brake discs
« Reply #13 on: 05 September 2007, 21:06:29 »
Usefull information .. thankyou ... Mr Haynes makes no mention of this... another printout added to the growing pile of tips from this site... by the time I come to do the work I'll have killed a dozen trees !!!
ians
  • Reading
Re: Brake discs
« Reply #14 on: 06 September 2007, 12:54:39 »
I wasn't aware they were directional but then I haven't installed any GM pads  :-[ (yet)
The pads on TC are very cheap so I would just keep them if they won't exchange them for the disks+pads (as you say probably the same ones!).
