Author Topic: Done paper clip test  (Read 2591 times)
bumbles5
  • margate kent
« on: 06 September 2007, 19:03:09 »
ok we did this paper clip test today and the eml light was flashing so many times it was unbelievable 1,3,10,9,6,1, all over the place there was no pattern to it at all. The eml light now we have put new bulbs in for him is on permanently vauxhall suggested the air flow meter so as we had one we changed that and it made no difference he has it in hopefully for a diagnostics test somewhere on saturday. But any ideas from you guys would be appreciated.
Re: Done paper clip test
« Reply #1 on: 06 September 2007, 19:48:29 »
Have you done the paperclip test correctly. Check this out.
http://images.omegaowners.com/images/guides/paperclip_test/paperclip.html
bumbles5
  • margate kent
« Reply #2 on: 06 September 2007, 21:22:11 »
Yep we did it following instructions given on here and knew what to look for i.e repeated patterns but it just did not seem to go like that it would only work with the key turned on not with the engine running when the engine was running the light was on permanently. we just kept getting different sequences 10 flashes - 3 flashes-10 flashes-1 flash-3 flashes-11 and so on it was not consistent.
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 06 September 2007, 21:41:46 »
Get it Tech'ed, if that can't read it either i suspect fubared ECU :(
« Reply #4 on: 06 September 2007, 21:59:56 »
a 10 is a 0...
Depending on age of your 2.0l, you may have 4 digit codes, rather than 2 digit codes on my car...
bumbles5
  • margate kent
« Reply #5 on: 06 September 2007, 22:11:26 »
The car we are doing it on is a r reg 98 if this helps.
« Reply #6 on: 06 September 2007, 22:14:23 »
Yes, possibly is 4 digit code on a 98 2.0l....
bumbles5
  • margate kent
« Reply #7 on: 07 September 2007, 07:15:31 »
Shame you guys arent nearer or we would have got you to come tech it for us. Oh well he thinks he has a garage doing it on sauturday if they can fit him in.
holey head
  • leeds uk
  • i'm a new dad
« Reply #8 on: 07 September 2007, 17:17:04 »
yes 4 digit codes. mine is a 99 and that is 4 digit codes! mine was giving out 0340.
ouch my head hurts! i'll try and remember to wear my helmet next time i'm out on the quad!
« Reply #9 on: 07 September 2007, 20:35:33 »
Cam sensor!
