Author Topic: 2.5 v6 removal of dis pack  (Read 1785 times)
road_rescue
  • Concrete Cow County
« on: 08 September 2007, 13:05:15 »
Whats the easiest way to do this? If somone can give me a clue that would be great, as I don't fancy rupturing myself again trying to fix the thing!
With sufficient thrust, pigs fly just fine.
saintnick
  • Portsmouth Hampshire
Re: 2.5 v6 removal of dis pack
« Reply #1 on: 08 September 2007, 13:24:40 »
i did it by removing the scuttle and windscreen wiper motor assmebly, take care when removing clips under rubber at base of windscreen, then you can remove plenum top and you can more or less look straight down on top of it, there are 4 torx bolts but i needed to use a 10mm socket i thik it was as there was not much clearance beetween the block and dis unit.
HTH
If It aint broke....Lets just dismantle it anyway!
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 08 September 2007, 13:25:36 »
wipers off, scuttle off, plenum off.
Long reach ( extension) pieces on your socket and jobs a good `un.
You wont be able to see what your doing but its done by feel - dis has 4 torx bolts, one in each corner.
Oh and be prepared to be cut and sore afterwards  ::)
road_rescue
« Reply #3 on: 08 September 2007, 13:29:02 »
thanks guys- i was going to go for it from underneath...
"Oh and be prepared to be cut and sore afterwards "
I'm used to the damn thing beating me up- i have only just recovered from changing the crank sensor :)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #4 on: 08 September 2007, 13:32:14 »
Do what TB does and get yourself a tunnie for jobs such as this.
tunnie (n)
A youth equipped with gadget arms who can be persuaded to assist in the more difficult to reach tasks of Omega maintenance.
TuBy's new whipping boy.
road_rescue
« Reply #5 on: 08 September 2007, 13:39:49 »
tunnie (n)
And where do I find one? can't seem to see one one eBay  ;D
« Last Edit: 08 September 2007, 13:41:06 by road_rescue »
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #6 on: 08 September 2007, 14:19:24 »
I believe they are only available in the Brackley area.
Here's what I use.
Don't forget the remote control.
 ;D ;D ;D
« Reply #7 on: 08 September 2007, 20:21:41 »
Aye, a Tunnie is very useful at times ;D.
Usually needs feeding though...
