Author Topic: Sidelight problem  (Read 2069 times)
megaomega123
Sidelight problem
« on: 11 September 2007, 13:11:01 »
My drivers side sidelight doesn't work. Works on full beam but not dipped. Have tried 3 different, known working bulbs, still no sidelight. There is no check bulb coming up on the MID either.
All the connections look intact and good.  Any ideas anybody?
    • E250 Est / Elroq
Re: Sidelight problem
« Reply #1 on: 11 September 2007, 13:36:36 »
does it work as a parking light?  (leave indicator in up / down position)
I had a sidelight I couldnt fix.....3 different HEADLIGHT bulbs I tried before someone pointed out my error  :-[
« Reply #2 on: 11 September 2007, 13:40:22 »
I is confused  ....  :-/
Is it the side light or the dipped headlight that is not working ???  They are TOTALLY different bulbs in different places !! (about 2 inches apart !! )
« Last Edit: 11 September 2007, 13:42:33 by entwood »
megaomega123
« Reply #3 on: 11 September 2007, 13:42:10 »
It does NOT work as a parking light either.
megaomega123
« Reply #4 on: 11 September 2007, 13:43:51 »
The inner bulb, which is dip and main or the knob turned to 1st position.
« Reply #5 on: 11 September 2007, 13:50:48 »
Still making no sense to me :(  I must be being thick today ..
On my mini-face lift with HID there are 2 bulbs there .. the side light bulb and the main beam bulb, the dipped lights are the HID projectors, so 3 bulbs in all,  side, dipped, main beam, all work when on main beam ... 2 work on dipped beam, only sidelight bulb at first position of switch, second position is main lights ?
« Last Edit: 11 September 2007, 13:51:40 by entwood »
megaomega123
« Reply #6 on: 11 September 2007, 13:53:42 »
No, it was me being thick, Sorry. I just found the smaller bulb next to the main beam bulb. It is out and ready for changing.
Sorry everyone, I should have looked more closely.
    • E250 Est / Elroq
« Reply #7 on: 11 September 2007, 13:55:55 »
LMAO  my first post did turn out to be relevent then!
Always pays to replace the correct bulb ;)
« Reply #8 on: 11 September 2007, 14:01:39 »
Alls well that ends well .....  what I call a "senior moment" nowadays.. :)
megaomega123
« Reply #9 on: 11 September 2007, 14:09:15 »
I seem to get them a lot. I'm only 33  :P
