Author Topic: Quick PC question  (Read 1137 times)
Nickbat
Quick PC question
« on: 28 September 2007, 19:07:40 »
I've got three hard drives on my PC (don't ask!  ::)), and I know I'm having trouble with one of them. There is a slight clicking noise which has started during read/write operations and the PC has slowed up considerably. This is confirmed by looking at the event log which is showing a few warnings and errors. The problem I have is identification. I know the logical drive letters, C, D, E and F, but the event log warnings refer to hard disk 0 and hard disk 1. Is there anyway I can identify these on screen? I'm pretty sure it's my C drive that has trouble and obviously it does have a partition but I don't know whether that partition is logical drive E or F?
Any thoughts?
Re: Quick PC question
« Reply #1 on: 28 September 2007, 19:19:06 »
hi, (assuming you have xp)
my computer (right click)-manage-disk manager
from there you will see the letters and partitions together
ps :good idea to check the disks for bad sectors
   + right click the partion you want -properties-tools -check disk
« Last Edit: 28 September 2007, 19:40:25 by cem_devecioglu »
Nickbat
« Reply #2 on: 28 September 2007, 19:45:15 »
I'll check that, but I use Win 2K Pro.  :(
« Reply #3 on: 28 September 2007, 19:49:43 »
if I remember correct ,was the same..
Nickbat
« Reply #4 on: 28 September 2007, 19:50:32 »
Thanks, mate. Just tried that and it showed that while Disk C is healthy, it's one of the others that isn't (Says "At risk"). That makes life easier as it should just a copy job rather than a system file swap..  :y
« Reply #5 on: 28 September 2007, 19:56:17 »
Glad you sorted  :)
« Reply #6 on: 28 September 2007, 21:26:26 »
At Risk means failure is very likely to happen very soon.  Copy data whilst you can ;)
