2.5 td auto box
Started by sadman43, 18 September 2007, 05:41:40
sadman43
Hi everyone, anyone help. when my auto box changes from second to third under moderate to heavy accelaration the gear box seems unable to select third and when it does the car jercks quite a bit as if the motor has misfired,  it feels like it can`t find third,  if i lift off a bit it changes up no prob, also if i go easy on the power it changes almost seemless throuh all gears, it`s better if i use sport mode, do I need a gear box oil change or is it more terminal.
I think the first stop would be an Transmission fluid change.
Tafty
Also, have you had the software updated to the latest version. TB or MDTM have transformed rough running automatics into smooth running limousines with the upgrade.  :y
QuoteHi everyone, anyone help. when my auto box changes from second to third under moderate to heavy accelaration the gear box seems unable to select third and when it does the car jercks quite a bit as if the motor has misfired,  it feels like it can`t find third,  if i lift off a bit it changes up no prob, also if i go easy on the power it changes almost seemless throuh all gears, it`s better if i use sport mode, do I need a gear box oil change or is it more terminal.
First port of call is to change the fluids...
sadman43
 :) Cheers folks will change the oil, not sure if it`s had the upgrade is there anyway of finding out rather than giving mr vauxhall a wad to check coz i just know he`l take a lump off me for doing the upgrade if it needs it.  :y
Quote:) Cheers folks will change the oil, not sure if it`s had the upgrade is there anyway of finding out rather than giving mr vauxhall a wad to check coz i just know he`l take a lump off me for doing the upgrade if it needs it.  :y
No way of checking....
Come to one of the meets - I'm sure we'll do the Lake District again next year - and we can do it....
sadman43
 :) cheers the lakes sounds a much better option will do, i`m a weekend gypsy so i`l bring my caravan with me. ;D
Quote:) cheers the lakes sounds a much better option will do, i`m a weekend gypsy so i`l bring my caravan with me. ;D
See you next year then :y
