Author Topic: rear brake change  (Read 1585 times)
wakedude
  • watlington,norfolk
rear brake change
« on: 21 September 2007, 16:45:15 »
I have only owned my omega for 2 weeks,i have discovered the rear pads,discs and calipers need replacing....doh!
Its a 98R 2.5 v6 estate
I thought i had checked the car thoroughly,but me and second hand cars dont go well,theres always something.
I attempted yesterday to change the parts,but after 3 hours of trying to get the disc off one side i gave up,it seems the handbrake pads are stopping it sliding off.
I bought a cd manual off ebay,but its still yet to arrive....typical!
Anyone with a few tips for me would be greatly appreciated,i beleive the handbrake adjuster is in the centre tunnel underneath???
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: rear brake change
« Reply #1 on: 21 September 2007, 16:53:42 »
I like red cars
wakedude
« Reply #2 on: 21 September 2007, 17:01:24 »
thanks,i used that but the problem i got is the 2 screws to slacken the shoes off are round off,and without a manual at the mo i dont know how else to slacken the handbrake shoes from off the drum/disc.
« Reply #3 on: 21 September 2007, 17:03:35 »
I assume the handbrake cable is slack as per the maintenance guide........
wakedude
« Reply #4 on: 21 September 2007, 17:08:52 »
yes the handbrake is off
« Reply #5 on: 21 September 2007, 17:20:53 »
Yes but, is the cable slack......
Its all to common for the handbrake to be adjusted using the cable and the result is the cable never goes slack (which it needs to or it will seize up)
« Last Edit: 21 September 2007, 17:21:55 by Mark »
wakedude
« Reply #6 on: 21 September 2007, 19:11:26 »
ok,i will check that tomorrow,going for round 2!
im not sure if the cable was slack,is the adjuster in the centre tunnel?
« Reply #7 on: 21 September 2007, 21:26:19 »
Yes, you have to pop the heat shields off as per the maintenance guide for the rear brakes.
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« Reply #8 on: 01 November 2011, 17:06:45 »
Could you please update the guide on this subject and make a little better explanation about where the parking brake adjuster is located. After reading this subject I now understand that it is in the driveshaft tunnel. The guide doesn't tell that.
Thanks
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #9 on: 01 November 2011, 17:10:59 »
Thanks
Jan
It tells you this "Get under the car and remove the heat shields which cover the hand brake adjuster"Once the shields are removed the adjuster is exposed ???
