Author Topic: Fob Problems  (Read 1937 times)
jorton
  • Hull
Fob Problems
« on: 27 September 2007, 00:17:35 »
Hi guy's, been having difficulty lately with my remote fob, opened it up and found the solder joints had snapped. i have been looking on ebay for a decent replacement and came across the zafira flip key fob.
The question is does any one know if the zafira flip key fob will work on a 99(T) omega cdx ??
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Fob Problems
« Reply #1 on: 27 September 2007, 10:37:48 »
If it looks the same it will work but it will need to be programmed to the car using a tech two I forgot to see where you where located there are a couple of people on here who could help you with this other than that its a vx dealer . Oh and you will also need the car pass for your car they need the secturity number to be able to help you. Can you not resloder the joints I managed it on mine ok
Dazzler
  • Haverhill, Suffolk
Re: Fob Problems
« Reply #2 on: 27 September 2007, 10:39:32 »
Try and find someone that is good at soldering and repair youe one, i did this to both of my fobs ;)
Re: Fob Problems
« Reply #3 on: 27 September 2007, 12:23:43 »
It needs to be same make (Bosch/Megamos/Delphi etc) and model (with/without LED) and technology (IR/RF).  If RF, it will need programming with a Tech2 machine as well.
jorton
  • Hull
Re: Fob Problems
« Reply #4 on: 27 September 2007, 12:30:24 »
cheers for the reply's guy's.
I would of tried to solder the break but both sides of the battery terminals have broke of and its broke flush with the plastic battery holder so not sure if the pins come out of the plastic casing. Ive super glued it as a tempory measure as i only have one key and it wouldnt let me in the car without the alarm going off..
Re: Fob Problems
« Reply #5 on: 27 September 2007, 12:32:35 »
Shame you are so far away - I sell keys and can program to your car (leaving you just to get the key mechanically cut by any key cutter)  :'(
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Fob Problems
« Reply #6 on: 27 September 2007, 13:40:01 »
Before buying another fob open it up and put some tissue on top of the battery then close it up again, I found that the tissue pushed the battery and its cradle far enough down to work :y
