Author Topic: Lamda Sensor  (Read 1234 times)
Machinmacone
  • Sheffield
Lamda Sensor
« on: 30 September 2007, 15:03:03 »
Hi all
         I've aquired a second hand sensor from a friend it was good when taken out and it is the correct one question is should i clean it at all and if so with what up to just i've just wiped it with a clean rag. Old sensor bringing up an intermittent code 38 which is high voltage O2 sensor i believe.
                           Thanks Julian.
                         ;D ;D ;D ;D ;D ;D
MikeDundee
  • Costa Del Peckham
Re: Lamda Sensor
« Reply #1 on: 30 September 2007, 16:25:00 »
Hi all
                           Thanks Julian.
                         ;D ;D ;D ;D ;D ;D
I believe its advised not to clean them; have a look here;
http://www.lambdapower.co.uk/diagnosis/diagnostic_index.asp#q16
Re: Lamda Sensor
« Reply #2 on: 30 September 2007, 17:56:36 »
The only way to clean them is with clean water and an ultrasonic bath (i.e. a jewellery cleaner).......this method even recovers the ones contaminated by a certain supermarket fuel.
Re: Lamda Sensor
« Reply #3 on: 30 September 2007, 20:10:26 »
I wonder if my brother would allow me to use his cleaner ::)
Machinmacone
  • Sheffield
Re: Lamda Sensor
« Reply #4 on: 05 October 2007, 02:27:52 »
Hi Guys
             Just an update fitted the sensor a couple of days ago eml now staying off problem cured.
             The old sensor had a white coating on inspection and from memory i think this is a sign of silicon contamination. So presumably sometime in the last few months i have been supplied dodgy petrol / lpg. Am i correct in this assumption?
             Any way thanks for the replies.
                                   Regards Julian.
                                  ;D ;D ;D ;D ;D ;D
