Code 59
Started by omegalord, 10 September 2007, 16:57:08
omegalord
Hi,
Just done my rocker gaskets and put everything back together.
No more leaking but the engine management light is staying on. I have done the paperclip test and it is coming up code 59 which is " 59 Inlet manifold valve 1 Low voltage " so ive been told.
How do i sort this?
Omegalord
The only thought I have is to recheck every electrical connection there is and make sure no cables have become trapped anywhere. If you didn't have the code before then I would suspect that something is adrift somewhere.
JasonH
The fault code info is here:
http://www.omegaowners.com/forum/YaBB.pl?num=1160152415
I think that means your rear multiram connector is off - right at the back of the plenum.
Yes, easy connector to miss off. right rear of plenum
omegalord
That connector is actually on. But can remember the rams didnt work before hand anyway.
Do you think it needed to be unplugged for the em light to show a fault?
Omegalord
JasonH
If it's unplugged with the ignition on, or perhaps the engine running, the fault will be logged. As soon as the fault is rectified i.e. the connector plugged back in the engine management light will go out. The logged fault can still be read with the paperclip until its cleared automatically by something like 20 clean engine starts.
omegalord
Regarding this Code 59!
Could you tell me if it is connector number 1 or 2 (see pic)
Matt
The Cambelt Kid
I've left this off by accident before, but spotted it during my final pre-start checks.  No.1 in the pic.
Marc
[color=green][size=18]Project LP6 has landed![/size][/color]
[color=black][size=12]DIY LPG now finally complete!! Whoo hoo.[/size][/color]
Yup....No1......No2 is the crank sensor.
omegalord
So its number 2? , the post above says its number 1?
Matt
My money's on number 1  ;)
QuoteSo its number 2? , the post above says its number 1?
Matt
Post corrected, I was having a blond moment.
omegalord
Thats no excuse. Your not ever allowed to make a mistake when it comes to cars  ;)
QuoteThats no excuse. Your not ever allowed to make a mistake when it comes to cars  ;)
Every god has to show human like behaviour now and again  ::)
omegalord
lol , yeah. I feel the same!
