Author Topic: ABS ECU TROUBLES  (Read 5791 times)
nixoro
  • Hitchin, Herts
ABS ECU TROUBLES
« on: 04 September 2007, 11:37:21 »
Yesterday I fitted a brand new abs sensor to no avail the problem was still there so I thought I'd have a look at the relays I have had troubles before so I thought I take the relays out I struggled to get the rear one out as someone had bent all the connectors on the unit and discovered it had been glued down.
Now I need to get my hands on a new unit as when I pulled the relay out it bought with it half of the connectors.
So is there anything I need to know regards changing and so on.
I have heard the unit from vx is £800+ so am going to try find a second hand unit.
Do the units need to have the same part number and are they easy to remove/change.
The car will be off the road from friday as its mot will be expired so atleast I will have time to work on the car.
All help on this would be much appreciated as I don't no really where to begin.
    • E250 Est / Elroq
Re: ABS ECU TROUBLES
« Reply #1 on: 04 September 2007, 11:41:56 »
There is a replacement guide in Maint Guides.
£800 sounds fitted price
Steve W who wrote the guide paid about £300 for a brand new one from Vauxhall
Others have bought from scrappers or even had theres refurbed.
If you buy new, I think Mark DTM is after a broken one to disect.
nixoro
  • Hitchin, Herts
« Reply #2 on: 04 September 2007, 11:45:55 »
If I can find a replacement unit then I would quite happily forward on the old unit.
I dont think my budget will stretch to a new unit but if I can find a second hand unit and it does the job then I'd be happy.
nixoro
  • Hitchin, Herts
« Reply #3 on: 04 September 2007, 12:09:18 »
Can some one find me the link for the guide as I have checked the maintenance guide section and could not spot it may have missed it :-[
Just found the link but not sure its what i'm after as its just the ecu removal i'm gonna need to take the whole unit out, not unless i have missed that bit too.
« Last Edit: 04 September 2007, 12:13:29 by nixoro »
    • E250 Est / Elroq
« Reply #4 on: 04 September 2007, 13:01:45 »
This is the one I was thinking of :
http://www.omegaowners.com/forum/YaBB.pl?num=1152729807
I believe some people have done this but not removed quite so many other bits.
MartinP
  • Dudley
    • BMW 320D
« Reply #5 on: 04 September 2007, 22:13:54 »
I did mine, http://www.omegaowners.com/forum/YaBB.pl?num=1168732737/0
Might help  :y
Didn't realise it was 8 months ago!
I used a torx bit from a screwdriver set with a 7mm spanner to rotate to get the screws out
« Last Edit: 04 September 2007, 22:18:55 by issunaz »
« Reply #6 on: 04 September 2007, 22:17:34 »
It might be worth you contacting BBA Reman ...
Worldwide Headquarters
BBA-reman Ltd
Unit 9 Sabre Court
Gillingham Business Park
Kent
ME8 0RW
United Kingdom
Phone: 01634 230 055
Fax: 01634 233 099
They took my ABS ECU checked, repaired, returned all in 5 days with a 2 year warranty for £120
I am well pleased with them
nixoro
  • Hitchin, Herts
« Reply #7 on: 06 September 2007, 12:44:31 »
How can you tell the difference between units and will I need an Identical one, obviously I dont need one with the TC but  I know where there are a couple of 2.0 omega's being broken, are earlier units the same as the later ones.
I know where there is an M reg 2.0 so was wondering if the unit would be the same.
All help on this would be gratefully appreciated.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #8 on: 06 September 2007, 13:17:22 »
i have recently had mine replaced, cost the AA £455, £281 of that was the unit itself.
Easiest way of IDing it would be by the bosch numbers, i would say there is no g'tee that you will end up with a unit that is better than the one you have, and i understand they are not the easiest things to get at or replace.......
« Reply #9 on: 06 September 2007, 14:10:16 »
Pretty sure you have the early 3 way one which is generaly VERY reliable and hence two a penny.
nixoro
  • Hitchin, Herts
« Reply #10 on: 07 September 2007, 12:26:27 »
Hi there
Cheers for the suggestion can you tell me where abouts the bosch number should be as I cannot see anything written on the top should it be on a sticker or imprinted somewhere.
If I can find the number I may have a word with vx to see what there price is for just the unit.
I'm guessing reprogramming will not be needed being that I will be moving the ecu over.
nixoro
  • Hitchin, Herts
« Reply #11 on: 07 September 2007, 13:52:43 »
Well just contacted Autovaux to get a price on a new unit very  :o :o :o :o :o :o :o nearly a grand for the unit and this was confirmed using the reg number what to do next :-/ may be lucky at the scrappers.
Cheers for all the help
« Reply #12 on: 07 September 2007, 13:58:51 »
As I posted above .. give BBA-Reman a ring ... must be worth it !
They sorted me out for a fraction of the vx quote
nixoro
  • Hitchin, Herts
« Reply #13 on: 07 September 2007, 14:10:23 »
Cheers for the number i called them the other day they need the part number before confirming if they can fix it.
« Reply #14 on: 07 September 2007, 15:01:40 »
Early one:
Later one:
Las jacarandas has a few early ones for about 25 quid each and there is a guy on ebay re-conditioning the later ones for a ton.
