Author Topic: Is it the leak off pipes?  (Read 2605 times)
alan2450
  • Ballymena, Northern Ireland
« on: 31 August 2007, 21:13:14 »
Hi all,
I have my 2002 CD dti for 4 weeks now and love it.  However i have a question, I have looked through the posts and I think that I know what the problem may be, but I do not have knowledge of you guys so looking for confirmation or other things to check! :)
Problem: If i have not started the car in 12 hours it is a bit difficult to start, turns over fine and then splutters into life after about 3-4 seconds (other diesels I have owned always started instantly?). The EML light stays on for about 8-10 seconds and then goes out. no more problems or lights until next period of inactivity.
If the car is not started for a number of days, then there is a need for continual turning over in bursts of 5-8 seconds and then eventually it will attempt to start and then will start after about 6-7 attempts (EML light again and then goes out). From what I have read, it is a fuel problem, air in system, faulty pump/s or the leak off pipes.
Thoughts or advice guys?
PS: Do not have a cheapo (yet)
VX1
  • Reading, Berkshire
Re: Is it the leak off pipes?
« Reply #1 on: 31 August 2007, 21:55:25 »
Hiya mate, I have the same problem with a car that I am repairing and yes it is the bleed off pipes, they will need renewing to solve the problem. If this works please let us know as of yet the guy that I am repairing the car for hasn't got the parts I need to sort the car out.
Cheers Paul :y
Vx Trade club card holder
Halfords trade card holder
alan2450
« Reply #2 on: 09 September 2007, 19:42:12 »
Well pipes have been changed and sadly the problem is still there  :( Anyone else have any advice or suggestions please?
Omegatoy
  • UK
« Reply #3 on: 09 September 2007, 19:55:25 »
if leak off pipes didnt cure it would suggest a set of glow plugs would be a good idea!!
MickAP
  • South Derbyshire
« Reply #4 on: 09 September 2007, 21:02:12 »
Had my glow-plugs replaced last January mine wouldn't start at all one very cold morning. It was ok when warmed up, but as soon as the engine went cold, wouldn't start. It would start with a squirt of "easy start" down the intake from cold although not recommended, only for emergencies. Garage said only 2/3 plugs were working. Not bad I think these were the original plugs that lasted 98000 miles, what mileage have you done?
Mick
alan2450
« Reply #5 on: 09 September 2007, 21:17:49 »
Cheers, It has just turned 100k so I think the plugs will need doing, I had planned to do them anyway before winter.  I will let you all know how I get on, will be the weekend before I have the time.  :(
alan2450
« Reply #6 on: 20 September 2007, 21:55:45 »
Well bleed off pipes changed, new glow plugs and new fuel filter with new seal and still the same problem.  We have had the car up on a lift and looked everywhere for any signs of a leak without sucess.  What's next to check?   :-/
alan2450
« Reply #7 on: 23 October 2007, 20:49:32 »
Problem Cured,  ;D
Had changed the bleed off pipes, problem was still there  :(
Changed fuel filter and seal, problem was still there  :(
New glow plugs, problem still there  :(
Starter F!*&ed, New starter, problem still there  :(
Got my nephew (23 years old) to have a look (Not much he does not know about car engines) He said straight away about copper washers on the fuel pump  :o, washers replaced and problem has gone  ;D
One happy teddy.  :y
