Author Topic: Break Discs  (Read 4582 times)
Eliteman Steve
  • Brighton
Break Discs
« on: 25 October 2007, 22:07:37 »
Hi Guys , am going to have to change the front discs soon , was wondering if anyone has bought discs from AutoVaux?
Also any advice on other bits I will need besides Discs and pads . :y :y
 :D
Re: Break Discs
« Reply #1 on: 25 October 2007, 22:09:01 »
Get a trade card via autobahnstormers ... then get the genuine disc/pads kit from vauxhall ... excellent stufff at a very good price..  :)
I did mine 2 weeks a go  :)
« Last Edit: 25 October 2007, 22:09:40 by entwood »
Markjay
  • London
Re: Break Discs
« Reply #2 on: 25 October 2007, 22:14:45 »
As Entwood says, Trade Club is best... did mine 6 month ago, I got a complete front discs and pads set for around £70 from my Vauxhall dealer.
Alas, no more Omegas....
Re: Break Discs
« Reply #3 on: 25 October 2007, 22:20:12 »
 :D
Pattern brake discs end up being expensive in the long run as you'll more than likely end up replacing them again with proper GM discs.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Break Discs
« Reply #4 on: 25 October 2007, 22:58:01 »
I would get new pad sensor cables too :y
Re: Break Discs
« Reply #5 on: 25 October 2007, 23:00:56 »
but they're jst a 'nice to have' rather than a 'must have'  ;)   :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Break Discs
« Reply #6 on: 25 October 2007, 23:03:19 »
Depends on how you look at it :)
Re: Break Discs
« Reply #7 on: 25 October 2007, 23:08:54 »
If the old ones have not put the warning lights on .. ie .. the pads are not fully worn .. the sensors can be re-used easily, just take care removing them .. DON'T do what Mr Haynes says ... "pry them out with a small screwdriver" .. that will wreck them. Leave them in position and remove them with the old pads, then remove from old pads, withdraw cable carefully. Do the opposite on fitting .. insert cable, place in new pads .. then fit to carrier.   Works easily  :)
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Break Discs
« Reply #8 on: 25 October 2007, 23:51:54 »
So how did you remove them without braking them?
Re: Break Discs
« Reply #9 on: 25 October 2007, 23:53:51 »
......So how did you remove them without braking them?
I've done as Entwood says & then use a slim pin punch to gently push them out.
kbou55
  • Tipperary, Ireland.
  • Peace, Through Superior Firepower
Re: Break Discs
« Reply #10 on: 26 October 2007, 01:46:41 »
the sensors are not dear to buy new, id get them anyway.
2002 Vectra 2.2 DTI Elite (for work)
2000 Zafira 1.8 Elegance (for the wife and kids)
2000 Honda Pan European ST1100 (for play)
    • E250 Est / Elroq
Re: Break Discs
« Reply #11 on: 26 October 2007, 07:52:26 »
Just realised we only have a disk change guide.
Anyone working / can do a full disk and pad change one?
Martin_1962
Re: Break Discs
« Reply #12 on: 26 October 2007, 16:38:23 »
AutoVaux ones are fine. I think they are OEM I have had no problems but I need some pads!!!!
ians
  • Reading
Re: Break Discs
« Reply #13 on: 26 October 2007, 16:52:15 »
The pads only on TC are very good value as I recall - not much over a tenner.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Break Discs
« Reply #14 on: 26 October 2007, 17:39:26 »
 When I come to do mine, I shall... I'll start on my HBV guide, see what y'all think of my writing "style"...
