Author Topic: elite with no fourth??  (Read 4109 times)
stumpy451
  • chesterfield, derbyshire
« on: 25 October 2007, 10:30:46 »
hi i have recently bought a 1996 3.0 elite (20-10-07) as someone wrote my CDX off  :'(  it has all the power it should but theres no fourth gear i have the recipt for a new gearbox that was fitted just before i bought it.
PLEASE HELP any ideas would be apreciated thanks.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: elite with no fourth??
« Reply #1 on: 25 October 2007, 10:48:49 »
Not stuck in sports mode is it?
I like red cars
stumpy451
« Reply #2 on: 25 October 2007, 11:15:09 »
The revs go a lot higher when changing between 1st, 2nd, 3rd when i press sports so i dont think so
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 25 October 2007, 11:36:39 »
Are the gearchanges smooth or a bit jerky?
Any gearbox warning messages or EML ?
Does the gear selector light up correctly?
It sounds like the gearbox is working off its hydraulics only, without assistance from the ecu....could be worth checking that the electrical connector is properly fitted to the 'box.
Matchless
  • Nottingham
    • A white van
« Reply #4 on: 25 October 2007, 11:38:12 »
But if it responds to Sports mode then ecu must be in control.....so get the codes read on Tech 2
stumpy451
« Reply #5 on: 25 October 2007, 11:42:53 »
no i dont get any warning lights and the changes are smooth. "so get the codes read on Tech 2" sorry could you explain this please i dont undestand. thanks
    • E250 Est / Elroq
« Reply #6 on: 25 October 2007, 11:59:16 »
You Don't mean that the selector goes 1 2 3 D N R P, and 4 is missing from that do you?  That is normal
Sorry If I am teaching to suck eggs here, just sometimes it is the simple things.
Matchless
  • Nottingham
    • A white van
« Reply #7 on: 25 October 2007, 12:01:08 »
Tech 2 is a Vx gadget which plugs into a socket on the car and can talk to the various control units (engine, gearbox, abs, airbag etc) If the gearbox ecu (electronic control unit) has spotted a problem with the box it will have stored a fault code that Tech 2 can read.
Where are you?  Update your profile with location and car details. There are a couple of members who could read codes for you if local otherwise its probably a trip to Vx. (most independent garages can read engine codes but not gearbox)
miggy
« Reply #8 on: 25 October 2007, 15:56:49 »
If your having no luck mate, I would give the garage who fitted the box a ring, see what they say, or ring the guy you had the car off.
« Last Edit: 25 October 2007, 15:57:04 by miggy »
philayl
  • Wirral, Merseyide
« Reply #9 on: 25 October 2007, 16:04:52 »
Hi, does it make three gear changes, watch the rev counter up to about 40mph to check that it does, if it does you have four gears.
p.s. welcome to the site
« Last Edit: 25 October 2007, 16:06:40 by philayl »
Danny
  • Wigan, Greater Manchester
« Reply #10 on: 25 October 2007, 16:20:19 »
selector problem??
« Reply #11 on: 26 October 2007, 21:09:02 »
Marks_DTM_Calib in Nottingham has a Tech2, and will be much cheaper than a dealer to plug it in.  Drop him a PM :)
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #12 on: 27 October 2007, 13:40:28 »
as a comparason 70 mph has my rev counter sat at just under 3000 rpm and 80 is about 3250rpm
if it does change into top it is normally done at between 45/50mph
philayl
  • Wirral, Merseyide
« Reply #13 on: 27 October 2007, 16:53:59 »
These figures sound about right to me, the movement you can feel at 45-50mph is the box locking down to eliminate slip.
« Reply #14 on: 27 October 2007, 18:07:10 »
Unless you get decent software on the box, which eliminates that horrid 50mph lockup.
