Author Topic: Querie regarding temp gauge  (Read 3166 times)
bumbles5
  • margate kent
« on: 03 October 2007, 19:30:28 »
Hi guys ok when we turn the engine on the temp gauge goes straight up over the red any ideas as to what this may be. It does it even when the engine is stone cold only just started happening.  If this is in wrong place sorry have put over in help as well.
Dazzler
  • Haverhill, Suffolk
Re: Querie regarding temp gauge
« Reply #1 on: 03 October 2007, 19:31:55 »
Sounds like the temp sender switch has failed mate.
« Last Edit: 03 October 2007, 19:32:06 by Dazzler »
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #2 on: 03 October 2007, 19:32:34 »
or the connector is earthing somewhere
Humbugs...
« Reply #3 on: 03 October 2007, 19:33:10 »
temp sensor lead shorting to 0v somewhere, or sensor itself gone short
bumbles5
  • margate kent
« Reply #4 on: 03 October 2007, 19:34:37 »
when we tap the instrument panel with your finger it goes down and then jumps back up we unplugged what we assume is the sensor from the rad and turned the key on and it did the same thing.
« Reply #5 on: 03 October 2007, 19:41:25 »
assuming no loom damage, knackered gauge then :(
bumbles5
  • margate kent
« Reply #6 on: 03 October 2007, 19:54:02 »
would you say the sensor is knackered or the actual temp gauge on the dash
« Reply #7 on: 03 October 2007, 19:55:30 »
There seems to be an echo!!!
« Reply #8 on: 03 October 2007, 20:28:06 »
critical component..if not changed will bring many problems..
« Reply #9 on: 03 October 2007, 20:37:41 »
??? All it means is that if the engine does over heat you won't know untill the steam come out from under the bonnet!  :-?
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« Reply #10 on: 03 October 2007, 20:48:14 »
[size=24]        [/size][/b]
« Reply #11 on: 03 October 2007, 20:55:02 »
also means a new engine or car ..
« Reply #12 on: 03 October 2007, 21:08:56 »
You are looking in the wrong place for the sender, it is at the back of the engine, drivers side...
« Reply #13 on: 03 October 2007, 21:09:32 »
It's a spade connector, I bet it has fallen off and is earthing on the cylinder head or an engine bracket...
bumbles5
  • margate kent
« Reply #14 on: 03 October 2007, 21:13:48 »
this is gonna be a fun one to find i can tell lol could it not just be the clock/gauge on the instrument panel lol.
