Author Topic: the TC button on the Dashboard  (Read 4646 times)
Wayne
« on: 21 November 2007, 18:50:46 »
I return !!   lol
just wondering that when you press the TC button on the car, should i notice a different "feel" to the car when driving it ?
i know its for Traction Control, but dont seem to feel any difference when its on
The Boy - you got any time FREE in the next week or 2 mate?
still want to sort this damn annoying heating problem out  ;)
James V6CDX - still up for doing me Gear oil change?
« Last Edit: 21 November 2007, 18:51:54 by Wayne »
Re: the TC button on the Dashboard
« Reply #1 on: 21 November 2007, 18:52:27 »
Pressing the tc button turns Traction Control off!
Wayne
« Reply #2 on: 21 November 2007, 18:55:00 »
i dont mean "press it"
when you turn the car on, it doesnt have the "TC" lit upon the dashboard where the speedo is
but when you press it, it comes on (obviously)
colalowe
  • Poole Dorset
« Reply #3 on: 21 November 2007, 18:55:59 »
As dbug says pessing TC turns the traction control off, you should get a warning light on on your dash, you will really only notice a difference in the wet, without TC the car will wheelspin easily.  ::)
Wayne
« Reply #4 on: 21 November 2007, 19:01:18 »
so...
when i get in the car and start the car up
the car will NOT display the TC light on the dashboard where the speedo is?
but IF i press it, i get the TC light up on the dash... meaning its on ? is that correct?
Grumpy
  • Manchester
« Reply #5 on: 21 November 2007, 19:02:47 »
No.
It's warning you that you've turned your Traction Control OFF.
colalowe
  • Poole Dorset
« Reply #6 on: 21 November 2007, 19:05:40 »
When you press your TC switch a light comes on on your dash which means the Traction control has been disabled.
The Traction control always defaults to ON when you turn your ignition on, you have to manually turn it OFF using the switch, I think the idea is for if you get you car stuck in mud/snow you can disable the tc. ::)
Hope this helps :y
« Last Edit: 21 November 2007, 19:06:20 by colalowe »
Wayne
« Reply #7 on: 21 November 2007, 19:12:11 »
THANKS MATE, very difficult to explain what i mean when just typing!  lol
cheers
Grumpy
  • Manchester
« Reply #8 on: 21 November 2007, 19:22:29 »
Judging by your Avatar, I guess you've been at the Sweet Corn again,
Wayne?   :)
Wayne
« Reply #9 on: 21 November 2007, 19:24:13 »
CANT STAND SWEETCORN!!    LOL    ;D ;D
« Reply #10 on: 21 November 2007, 20:27:19 »
TC light means the TC is OFF.  Very few occasions when you would need to turn it off..
hotel21
  • The Kingdom of Fife
« Reply #11 on: 21 November 2007, 21:47:55 »
Playtime??   8-)
bigdods
  • Brackley
« Reply #12 on: 21 November 2007, 21:51:33 »
Easy to check this time of year. Find T junction. Stop at junction. Accelerate hard while turning right (or left it doesnt matter) from a standing start. You should see the TC light flash and the car will slow down. Do same again with TC button pressed, should get some jolly nice wheelspin and perhaps a 180 if you try hard enough ;-)
« Reply #13 on: 21 November 2007, 21:53:05 »
Trying to pull away from a snowy junction! TC doesn't always know best!  >:(
« Reply #14 on: 21 November 2007, 21:59:44 »
I disagree.  Either the 2 v6s I've had with TC had something wrong with them, or you have something wrong with yours, or you are not lifting off to release it a bit quick enough.
Last proper snow we had, it was the beemers around here going nowhere, mine was fine. And TC enabled, and snow mode on box.
And the MV6 is on 235 rubber, hardly ideal for icey conditions...
