Author Topic: Omega sump  (Read 1334 times)
PhilG
Omega sump
« on: 02 October 2007, 21:31:28 »
I have just bought an Omega 2 litre engine which I hope to fit into an Opel Manta 'A' series. I hope this does not offend any purists. It seems one of the first hurdles will be the sump. Does any body know if there is a sump that will fit back to front as the oil well snags the Manta cross member as it is.
Cheers for now
PhilG
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Omega sump
« Reply #1 on: 02 October 2007, 21:34:33 »
Hi, welcome to the forum.
I'm going to move this to the 'General Chat' area, as we keep this section for Omegas only.
I like red cars
Re: Omega sump
« Reply #2 on: 02 October 2007, 21:37:56 »
Not something I've ever looked at to be honest....
Re: Omega sump
« Reply #3 on: 02 October 2007, 23:21:39 »
..... I hope this does not offend any purists.  ......
I'm not a 'purist' but to me you'e adding a load of uneccessary complexity to what was quite a basic easy to work on car. A lot of Manta B's tend to get the Cavalier red top engines fitted.
Re: Omega sump
« Reply #4 on: 03 October 2007, 09:51:00 »
I'd say a C20XE is a more often trodden path and that engine will make more power than the Omega lump. Finding a good one is getting less easy now though.
You can always keep it simple using a conventional distributor and a pair of 45DCOEs with the C20XE. Should still be good for 160-170 BHP.
I would guess that you need to use some form of engine management with the Ecotec due to the lack of a distributor, not that that's too hard to sort out these days. I would probably go for an aftermarket injection setup (probably a Megasquirt, knowing me :y) and independant throttle bodies rather than try to get the Omega's engine management to work in the Manta.
Sounds like a fun project, though. Keep us updated and good luck :y
Martin_1962
Re: Omega sump
« Reply #5 on: 03 October 2007, 09:54:22 »
I'd be tempted to take the ECU as well
PhilG
Re: Omega sump
« Reply #6 on: 04 October 2007, 19:29:07 »
Thanks for your comments and views. It looks as if I  will have to do a bit more research. I was hoping there may be a conventional distributor and carb's that will fit. The engine doesn't owe me anything so I can afford to look and see what's best. The old engines well dead so this is worth pursuing - I think.
