Author Topic: its my birthday  ......and i need help  (Read 2606 times)
jim513
  • london
« on: 23 November 2007, 14:31:20 »
hello all
today is my birthday ..was really looking forward to a good day....sadly i'm locked out of my omega..(think it might have a flat battery)...and central locking is not working......nor is manually using key.....any suggestions would be gratefully recieved....and a pint if your local hehe....HELLLLLLLP!!!!!
Re: its my birthday  ......and i need help
« Reply #1 on: 23 November 2007, 14:34:20 »
Key in the drivers door and force it clockwise.....it will be worrying to do but it will go.
Or get in through the boot.
jim513
  • london
« Reply #2 on: 23 November 2007, 14:42:17 »
Thanks will try that.....the boot thing i looked at but being thick when it comes to these things i just looked and thought how the hell do i get in without breaking something.....or is that the only way
« Reply #3 on: 23 November 2007, 14:46:31 »
What age car....?
jim513
  • london
« Reply #4 on: 23 November 2007, 14:49:21 »
oh yeah that would help i spose...(told you i was thick)....its a 98 2.5 v6
« Reply #5 on: 23 November 2007, 14:50:46 »
Yep, you can get in through the boot, you have to give the ski hatch between the seats a kick (if its a saloon) to open it.
The key in the drivers door lock is the best method....
jim513
  • london
« Reply #6 on: 23 November 2007, 14:56:34 »
Thanks mate....will try the key....then the boot.....a big size 10
jim513
  • london
« Reply #7 on: 23 November 2007, 17:08:32 »
quick update the key thing worked...thanks......as i suspected had a flat battery.....now i know why.....i turned the ignition off....but it doesnt actually go off.....as i walked off i turned round to see the ignition lights still on....had a play and no joy......i've left the battery disconected....is this wise.
                              desperate Jim...(having a crap birthday)
    • E250 Est / Elroq
« Reply #8 on: 23 November 2007, 18:42:26 »
I've had similar on an old cavalier, was the alternator was knackered :(
STMO123
« Reply #9 on: 23 November 2007, 19:26:54 »
Fully charge the battery, see what happens. A flat battery on a modern(ish) car can cause all manner of faults.
jim513
  • london
« Reply #10 on: 24 November 2007, 02:08:20 »
thanks for the advice stmo.....hope to god your right......would hate to have to go back to the coach and horses..(unless it was a pub)
The Cambelt Kid
  • Derby
« Reply #11 on: 26 November 2007, 20:34:06 »
Hi Guys,
I have the same prob.  Im locked out of my other 2000 model and can't get in.  I don't think the boot thing will work as i have a post 2000 model.  For some reason the drivers door lock thing fails too, after a bit of force clockwise it goes click and the nob jerks updated a few mm and then drops back down... :o(  I've applied quite a lot of pressure c/wise and it does not budge.
Am i doing somthing wrong or do i need to apply more force?  any more and my hand will explode!  :o
Is there any power connections i can apply the charger to?  I don't have the plastic tray attaced under the car so i can get to a few things... ?
« Last Edit: 26 November 2007, 20:35:29 by Omega2000w »
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
mikkethealarmguy
  • kent
« Reply #12 on: 26 November 2007, 20:39:44 »
you can stick a live on the starter motor live wire.
or you can jiggle the key left to right as it also works.
ive not tried sticking a live to the starter cable before so be careful.
works on some cars..
The Cambelt Kid
  • Derby
« Reply #13 on: 26 November 2007, 21:04:11 »
For some reason i suddenly opened!  I forced it c/wise as advised and the nob didn't pop up so i gave it a go and it opened!
Thanks
