Author Topic: Shocks Time  (Read 1572 times)
philayl
  • Wirral, Merseyide
Shocks Time
« on: 28 November 2007, 12:08:06 »
Hi all, it is replacement time for the shock absorbers, I believe the backs are fairly easy to do, are the front shocks an easy job to do. Does anyone local to me fancy earning some cash doing them for me? I used to do all my own repairs but I am at the age now where I can still lie on the floor, just have a problem gettting back up again. :(
Re: Shocks Time
« Reply #1 on: 28 November 2007, 12:14:44 »
Rears easy if bolts dont seize.
Fronts fairly easy, but will need spring compressor, and camber reset afterwards...
philayl
  • Wirral, Merseyide
Re: Shocks Time
« Reply #2 on: 28 November 2007, 12:21:48 »
Cheers TB, I don't have spring compressors, but will have to get someone in to do it anyway, last time I enquired about a full geometry check the only local one to me capable of doing it, besides the main stealer, wanted £460. I just loosened the bolts on the bottom of the leg that the tyre wear was on and pulled it out, it has been fine ever since, I was very lucky to get away with doing it that way.
Re: Shocks Time
« Reply #3 on: 28 November 2007, 13:15:17 »
Ive got some, just give me a shout if you need them :y
philayl
  • Wirral, Merseyide
Re: Shocks Time
« Reply #4 on: 28 November 2007, 19:48:41 »
Cheers Elite Pete, will do, although I will probably have to put it in somewhere to be done.
