Author Topic: elec heat problem  (Read 1993 times)
salvo3.0
  • wiltshire,swindon
elec heat problem
« on: 27 November 2007, 18:59:21 »
just got my motor back the garage , still no heater!!
the man told me there is a electical problem with the air con,
every time i put on the heater to get hot air the air con comes on and blows cool air,
10 seconds of hot ,then cool .
has any body come across this problem before?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: elec heat problem
« Reply #1 on: 28 November 2007, 07:35:44 »
Anyone?
I like red cars
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
« Reply #2 on: 28 November 2007, 08:22:49 »
I've got the same problem...I would appreciate some advice too.
Growing old disgracefully...
Mike Collins
  • North of Bristol
« Reply #3 on: 28 November 2007, 08:43:41 »
Does the engine reach normal operating temperature reasonably guickly? If not, thermostat.
Feel the two pipes going through the firewall to the heater matrix, drivers side, about level with the cylinder head. Both should be hot, if only the top is then possibly an airlock or blockage in the matrix.
salvo3.0
  • wiltshire,swindon
« Reply #4 on: 29 November 2007, 19:35:14 »
just got the car back from the garage , then straight to the auto electrian £300 pounds down and still no heating in the car!
they repaired the heating solniod, vac pipes, then tell me to take it back to the garage to flush the matrix,
can someone tell me exactly where the pipes are to flush the matrix and i'll try it myself first.
getting bored throwing money away.
all a want is the heater to work.
can someone show me how please!
jorton
  • Hull
« Reply #5 on: 01 December 2007, 13:04:38 »
Hi, just had a similar problem myself....to locate your heater pipes...when looking in the engine bay, look in the left hand side (drivers) near to where the brake servo is, theres 2 vac pipes leading off the servo pipes if you look under there on the bulk head there are 2 rubber hoses one on top of the other, one has a black plastic end the other has a white plastic end theses come off (can be a sod to get off) to reveal 2 metal pipes, this is the supply and return for you heater matrix, if you need any more help i'll tahe a photo of mine and send em to you.... :y
« Reply #6 on: 01 December 2007, 16:29:30 »
If the pipes to matrix are getting hot, and the climate has been reset, then you are looking at issues with the panel or sensors.  Is the sampling fan working?
Page created in 0.008 seconds with 16 queries.
