Author Topic: Brake Pad message on MID  (Read 3670 times)
wayneywoo
  • Hemel Hempstead
« on: 29 November 2007, 22:07:08 »
Hey All,
Everytime I start the car, I get the message "Brake Pad" on the computer.  Can someone explain what's going on here please?
Many thanks!
Wayne
Hemel
Re: Brake Pad message on MID
« Reply #1 on: 29 November 2007, 22:18:26 »
Replace your brake pads they're worn!!!
« Last Edit: 29 November 2007, 22:20:41 by dbug »
wayneywoo
  • Hemel Hempstead
« Reply #2 on: 29 November 2007, 22:20:29 »
Previous owner said he just had the pads changed and went through the MOT no probs...
He said something about sensors but I wasn't paying too much attention  ::)
« Last Edit: 29 November 2007, 22:23:47 by wayneywoo »
« Reply #3 on: 29 November 2007, 22:22:57 »
Maybe he just said he did!!  Low pads can and do pass MOT brake test!
If u are sure pads OK then maybe pad sensors breaked!!
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 29 November 2007, 22:38:36 »
Hey All,
Many thanks!
Wayne
Hemel
Check that the sensor wire hasn't come out of the pad mate, I bought new pads myself when the "Check Pads" came up on mine, only to find when i removed the wheel that the wire had come out ::)
The sensors are only on the front pads (one each side). If the sensor wire is broken they are less than £10 from Vauxhall anyway :y
This link shows a picture of a front pad where the sensor pushes into.
http://www.omegaowners.com/forum/YaBB.pl?num=1192573698
wayneywoo
  • Hemel Hempstead
« Reply #5 on: 29 November 2007, 22:40:44 »
Thanks Loo-Knee  :y
I shall investigate tomorrow.
Wayne
Missy_MV6
« Reply #6 on: 30 November 2007, 06:47:30 »
We changed our pads with non-vauxhall ones which means the brake pad sensors are not used and because of this the brake pad warning is displayed. A friend told us to wrap the 2 sensor wires (on each sided) together and the warning should go off.Tried it and it didn't.
Unfortunately in your case you don't really know if the pads have been changed or not.
You could buy some Vauxhall ones and get them changed just to be on the safe side. ;)
    • E250 Est / Elroq
« Reply #7 on: 30 November 2007, 08:27:07 »
disconnected ours by unplugging the sensor, sticking a paperclip in the sensor socket, wrap in tape, works perfectly.
No error message  :y
wayneywoo
  • Hemel Hempstead
« Reply #8 on: 30 November 2007, 08:42:41 »
How much are the genuine Vauxhall pads just out of curosity?
Thanks for all the replies people!
Wayne
« Reply #9 on: 30 November 2007, 11:15:34 »
£21.55+Vat retail per axle set....plus sensors.
davlad22
  • Sunny Yorkshire
« Reply #10 on: 30 November 2007, 15:48:36 »
new sensors are only a few quid.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #11 on: 01 December 2007, 14:06:05 »
Pads are on the trade club list :y
« Last Edit: 01 December 2007, 14:06:35 by Tony_H »
wayneywoo
  • Hemel Hempstead
« Reply #12 on: 01 December 2007, 16:20:29 »
So how much are the pads to a trade club member?
Anyone near Hemel Hempstead have a Trade Club membership?
« Reply #13 on: 01 December 2007, 16:25:40 »
About £12 + VAT from memory.
You can get TC membership for £20 per year by joining Autobahnstormers ;)
« Reply #14 on: 02 December 2007, 22:35:39 »
Oh dear! Yet more dis-information. Neither OEM nor pattern pads come with sensing wires fixed to the pads. (I know that Fords of the early 80's came with or without wires embedded in to the pads - maybe you had a Ford of the early 80's :-/) If you were to look through the many many repeated questions & their answers you'll find that the sensor wire(s) are completely seperate from the pads. One end clips onto the butterfly anti-rattle clip fixed to the pads & the other plugs in under the front wing. If you bare the wires to a 'used' sensor & short the 2 ends together it WILL fool the brake pad check system. Tried it and it DID  ::)
How about checking them the old fashioned way and remove the wheel & have a proper look at both pads! That way you'll really know if they've been changed! :-?
The last time my low  pad warning check was displayed I'd still at least half of each pad left.
Page created in 0.037 seconds with 20 queries.
