Author Topic: Do Cat,s Die  (Read 5093 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Do Cat,s Die
« on: 04 December 2007, 15:48:13 »
Had the light back on the dash and had it checked out and told that the cat, s where showing low efficiency on bank 1 and 2. They then chack the emission at they where fine. Just to check it any one has had this before and if it could be the 02,s playing up as they seem to do on this 3.2 V6. The guy told me that the cats should be good for the life of the car and as it does 95% M way driving and not driven hard.
Any help please.
Thanks
CateraMV6
  • Lake Orion MI, USA
  • 2001 CATERA SPORT
    • 2001 Cadillac Catera SPT
Re: Do Cat,s Die
« Reply #1 on: 04 December 2007, 17:28:07 »
Ummm I may be wrong but I think that this belongs to the TECHNICAL Forum...  :y  you might get more help there...
Re: Do Cat,s Die
« Reply #2 on: 04 December 2007, 18:52:38 »
Any help please.
Thanks
Yes, cats do die.  If its ever had a misfire, they may well be shot.  Then again, it could be lamdas...
Re: Do Cat,s Die
« Reply #3 on: 04 December 2007, 19:17:28 »
Any help please.
Thanks
Funny that they're saying both cats are playing up at the same time :-/ Makes me think something else might be throwing out the fuelling, especially as an emissions test shows it to be OK.
Re: Do Cat,s Die
« Reply #4 on: 04 December 2007, 21:21:31 »
bad lambdas, spark plugs, DIS even oil additives can cook CATS ..
But when I de-cat , I examined inside and seems not very easy to clog or become bad  :-/
Re: Do Cat,s Die
« Reply #5 on: 05 December 2007, 08:24:20 »
They dont die unless damaged......
    • E250 Est / Elroq
Re: Do Cat,s Die
« Reply #6 on: 05 December 2007, 08:35:43 »
Or Mark leaves em in the water butt for too long  ::)
SP_3.2
  • Leicester
Re: Do Cat,s Die
« Reply #7 on: 05 December 2007, 09:22:43 »
Car seems to run fine no missing and same MPG :-/
was thinking 02 as i think that i would be right in saying that the cats do not have a sensor in them. So i am thinking that the post and pre 02,s are the only way that they ecu would know how things are working with the cats.?
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Do Cat,s Die
« Reply #8 on: 05 December 2007, 09:45:08 »
Is that how you tell whether they're punctured? :D
    • E250 Est / Elroq
Re: Do Cat,s Die
« Reply #9 on: 05 December 2007, 09:58:27 »
Its only a reliable indicator they've been caught crapping in his garden  ;D
Re: Do Cat,s Die
« Reply #10 on: 05 December 2007, 10:41:02 »
The cat itself has nothing clever in it. It's just a honeycomb of materials which act as a catalyst in the breaking down of exhaust gases.
The pre-cat Lambda sensor is there to control the fuel mixture the engine burns. It provides the right conditions for the cat to work by controlling the engine's mixture to provide the right balance of gases in the exhaust. It's not affected by the cat and doesn't detect what the cat is doing.
The post-cat Lambda sensor is what aims to detect the cat's efficiency. It's there to ensure that the small amount of oxygen in the exhaust gas before the cat, is removed by the cat in the course of doing its' job. It also tells the engine management system when the cat starts working, so the engine management system can employ techniques to warm the cat more rapidly from cold.
The post cat Lambda sensor doesn't affect engine running, it's only there to ensure that an emissions failure resulting in the cat being ineffective is picked up by an EML. Ironically, these are less reliable than the cats they're monitoring. I suspect the exhaust gases are sufficiently cooled by the time they reach this part of the system that harmful deposits don't get burned off them (despite the fact that they have internal heaters so the sensor element actually operates red hot).
I guess you've got an issue with the post cat sensors (odd that they both misbehave at once, though) or that the emissions from the cats do go outside limits under some operating conditions for another reason (thus lighting the EML) but that the emissions are fine during MOT test conditions (idle and fast idle).
A few people with 3.2s have issues with these sensors. I have had the same once, when the contaminated fuel scare was on in february but it has not recurred. It would be interesting to get a tech2 on one of these cars and watch the live data to see what is going outside limits and when.
SP_3.2
  • Leicester
Re: Do Cat,s Die
« Reply #11 on: 05 December 2007, 10:57:48 »
Thank,s Kevin
Thats a great write up and i am thinking the post 02 could be the prob, one has been replaced in the last few months.
Thanks
Steve.
Re: Do Cat,s Die
« Reply #12 on: 05 December 2007, 11:25:45 »
If you can get access to an ultrasonic cleaning bath, remove the sensors and give them a clean.....
SP_3.2
  • Leicester
Re: Do Cat,s Die
« Reply #13 on: 05 December 2007, 11:32:52 »
Hi
Would you know of anywhere that would do that.Or is there any other way of cleaning them,
Thanks  :y
Steve.
Re: Do Cat,s Die
« Reply #14 on: 05 December 2007, 12:07:51 »
I keep meaning to buy one...they are only about 25 quid.
Page created in 0.506 seconds with 20 queries.
