Another heated front seat Q...
Started by Taxi_Driver, 16 December 2007, 22:59:39
Taxi_Driver
So 1-4 on the switch.
Set it on 1 and after 10-15mins i have to turn it off........its burning my bum!  :o
Set it on 2 or 3 doesnt make any difference
So how do they work......is there a thermostat in the seat? .....or does the switch just control voltage going to the heater?  :-/
Whats likely to be wrong?
Auto Addict
I like red cars
QuoteSo 1-4 on the switch.
Are both front seat switches the same? Is it possible to swap them over to test each side's circuit/switch?
The switch is nothing more than a contact and a seperate variable resistance that is fed to a controller in the seat base......try another switch.
old cruiser
Mark when you say the controller in the seat base; is this accessible from under the seat itself or does the seat cushion have to be removed? as this could be what's wrong with mine .
Cheers Pete
Taxi_Driver
QuoteThe switch is nothing more than a contact and a seperate variable resistance that is fed to a controller in the seat base......try another switch.
Ok will do Mark.
Cheers  :y
