REAR WINDOW DE-MISTER
Started by knitware, 20 December 2007, 11:42:42
knitware
Hello again-
I was hoping that one of you on here may have had this problem and rectified it.
My rear window de-mister is rubbish, it works slightly. After about 5 mins you can see it starting to de-mist. I think that the mirrors are linked to the de-misting switch and they too are slow, but not as slow as the rear window.
Also when I turn the de-mister on I get an interference through the radio, like a crackling noise.
It's important that I can de-missed at this time of year, any clues?!?
knitware
Sorry, its a 2001 2.6 CDX, may make a differance.....
bigdods
Sounds like you have a loose connection or a short somewhere. I would guess the radio interference is caused by the poor connection which will also give you reduced current hence it working very slowly.
Im no expert so I cant say what you might do to fix but I am sure someone will be along shortly to tell you which relay/fuse to remove and reseat, and what connectors to clean.
Does the rear window clear evenly or ar there any gaps ? If there is a gap (where an element isnt working) that could cause problems, can be fixed with conducting paint available from halfords.
bigdods
Just found another thread on the same subject, might be worth a look
http://www.omegaowners.com/forum/YaBB.pl?num=1197907234
knitware
Thanks for the clues!
The rear window de-mist's evenly but never clears fully. I shall check the connectors under the parcel shelf and the fuse for it. It does sound like though it could be one of those things to live with, I'll check connections first before I get too dispondant!
Danny
QuoteThanks for the clues!
do you have plenty of heat coming into the car with your heaters? this should help with demisting if your car's toastie inside
knitware
Yes the rear window clears if i'm on a run because the aircon clears it.
I just wish I could press the button and the screen clears, like in my wifes car, her's take a minute to clear!
I shall do some checks tomorrow morning and see if a wiggled wire will help,.........mmm
