Author Topic: Washer jets!  (Read 6810 times)
donut82
  • Lincoln
Washer jets!
« on: 19 December 2007, 18:08:03 »
Cleaned the windscreen on the way to work, no problems. Came back home and just got dribs and drabs, out of water....obviously.
Checked the bottle and it was half full but topped it up anyway but can hardly get any water out of the jets. I have to keep flicking the indicator stalk to get drabs of water but hold it back and all I can hear is the pump, so now I just have the wipers going like mad and smearing the screen.
Had a go at jets with a pen to clear and blockage and looked at the pipe as best as I can going from the bottle to the jets and everything seems fine.
Am I missing something blatantly obvious? :-?
Faster, faster...........thats broke it!!!!!
2005 Veccy SRi V6 CDTi now for sale........GOING MV6 HUNTING!!!!!!
ians
  • Reading
Re: Washer jets!
« Reply #1 on: 19 December 2007, 18:11:25 »
I think there is a filter in/on the tank which may have clogged.  Its unlikely both nozzles would get blocked at the same time.
Martin_1962
Re: Washer jets!
« Reply #2 on: 19 December 2007, 18:13:11 »
Take out the jets and reverse blow them
amba
  • Medway towns
    • German V6
Re: Washer jets!
« Reply #3 on: 19 December 2007, 18:15:05 »
Check pump to ensure it is pushing water to jets..easiest way is to split pipe where it comes out from beneath pollen filter end of scuttle panel grille.If water is being pumped at that point blockage is in jets on bonnet and best thing is a sewing needle or pin to clear jets...if no water at resonable pressuer is evident at pipe then pump filter is almost certainly blocked with crud.
You then need to remove the washer pump from the filler tank behind front bumper which you can get to from above..inside hole when pumps is out is a small filter which gets blocked up..that should sort your problems
Re: Washer jets!
« Reply #4 on: 19 December 2007, 18:17:01 »
As IanS says there's a filter in the bottle. If you remove the grill (pre facelift cars) and pull the pump from the tank - a push fit - you'll see that the grommet it sits in has a little filter built in. It looks like a mini waste paper basket!  ;D Clean all the sh1te from it and rebuild.  :y
Re: Washer jets!
« Reply #5 on: 19 December 2007, 18:19:57 »
Just be carefull in this cold weather when pulling washer tube from pumps & washer nozzles as it's easier to break the 'nipple' off .... ooer! :o Hot water or your (wife's/girl friends) hair dryer will soften the tube if you really need to remove it.
donut82
  • Lincoln
Re: Washer jets!
« Reply #6 on: 19 December 2007, 18:24:03 »
Cheers people :y
donut82
  • Lincoln
Re: Washer jets!
« Reply #7 on: 19 December 2007, 18:53:36 »
OK, been out and checked everything at its pointing to a blockage in the filter cause theres hardly any water coming through the system.
So can someone do me a step by step on how to get into the pump filter as A) I'm abit retarded and B) I don't want to break the bloody thing, which I have a tendency to do :)
Re: Washer jets!
« Reply #8 on: 19 December 2007, 19:09:00 »
Open driver's door
Pull bonnet lift .....  ;D
Your washer bottle lives at the front of the car, between the head lights. I assume it's a face lift car, so there's no grille to remove. The smaller pump is the screen washer pump (if you have HID lights you'll have a bigger pump too) and as said is just a push fit into the grommet/filter in the washer bottle. Ease the pump out of the bottle, remove the grommet/filter & wash the cr4p out of it. Rebuild.
« Last Edit: 19 December 2007, 19:10:12 by Andy_B »
donut82
  • Lincoln
Re: Washer jets!
« Reply #9 on: 19 December 2007, 19:47:19 »
Ta muchly....I forgot to open the door to get to the bonnet pull, thats where I was going wrong  :y
Re: Washer jets!
« Reply #10 on: 19 December 2007, 19:56:43 »
LOL  ;D I was a while back since I did mine, AFAIR I didn't remove the bottle to get to the pump. Just prise the pump out gently. I'd wait till it was light though. ;)
I think I need to have another look aqt mine as when I tried to wash my screen on the motorway the other day - I could see f*** all! :o Plenty of wipers but sod all water, all as I was about to join the M6. So far it's fixed itself, but a proper flush through won't go amiss.
Re: Washer jets!
« Reply #11 on: 19 December 2007, 21:04:57 »
pump can fail also..I changed mine..
also normal city water clog the jets in time  ..necessary to use pure water (no lime) or one with antifreeze mixture..
hotel21
  • The Kingdom of Fife
Re: Washer jets!
« Reply #12 on: 19 December 2007, 22:24:37 »
If its cold as a cold thing, they may be frozen as no additive  (50/50 mix preferred) if its as cold as a witches t*t outside....
And your jet heaters are also fubar..... :y
« Last Edit: 19 December 2007, 22:24:48 by hotel21 »
    • E250 Est / Elroq
Re: Washer jets!
« Reply #13 on: 20 December 2007, 09:42:13 »
If the jets neet attention as well, the only thing I find works well is fine picture hanging wire, thin enough to have a good clean around with, pins and similar often too fat
Martin_1962
Re: Washer jets!
« Reply #14 on: 20 December 2007, 10:10:45 »
You need to also blast them clean from the outside - gunge gets trapped by the jets and cannot get out.
Facelift ones are easy to clean
