Author Topic: Slippery When Wet  (Read 3922 times)
Bo Bo
  • Coventry
Slippery When Wet
« on: 05 October 2007, 08:13:26 »
I was chatting to a chap at work earlier this week saying how easy it is to get my car sideways in the wet & he said that's because you have fat tyres & the wider they are the more rain gets trapped in the grooves & you loose traction  :-?
Re: Slippery When Wet
« Reply #1 on: 05 October 2007, 09:00:00 »
Nought to do with the 207bhp under you're foot then....
hotel21
  • The Kingdom of Fife
« Reply #2 on: 05 October 2007, 10:12:49 »
Your chap at work does have a point though.  If I recall correctly SAAB and others used to put narrow tyres on their rally cars when going through snow covered stages.  Idea was that the tyre width cut through the snow rather than sitting on top and compacting it, thus giving some steering/drive.
When the tread pattern is slightly down on tyres as wide as those on an Omega they may not disperse water as quickly or efficiently.  This allows the power at the wheels, in common with other powerfull cars, to supercede grip and car to loose traction.
Bo Bo
  • Coventry
« Reply #3 on: 05 October 2007, 10:21:16 »
I said at the time that I see his point but at the same time I would have thought there's more rubber on the road  :-?
« Reply #4 on: 05 October 2007, 10:27:35 »
If you want more rubber on the road, drive on bald tyres! Seriously the tread is there to get rid of the water when it's wet.
IrmscherKris
  • Manchester
  • banned due to bad trader references
« Reply #5 on: 05 October 2007, 12:01:52 »
Slicks are the way forward  :y
Expect 12 points off the plod if you get caught though!
« Last Edit: 05 October 2007, 12:02:09 by irmscherkris »
Taxi_Driver
« Reply #6 on: 05 October 2007, 12:29:20 »
Is it true to say that the 'V' shape pattern you see on some tyres are better at dispersing water?
IrmscherKris
  • Manchester
« Reply #7 on: 05 October 2007, 12:32:01 »
I think so, it sort of creates a channel for the water to escape.
« Reply #8 on: 05 October 2007, 16:28:24 »
In rain, wider tyres (with good tread) better - more surface area, and decent tread stops it aquaplaning.
In snow/ice, narrower tyres, and wider tend to sit 'on' the ice rather than 'through' it...
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #9 on: 05 October 2007, 17:38:34 »
The old Morris Minors were good in snow due to there large diameter yet thin tyres
One of the best rubber lubricants is water
« Reply #10 on: 05 October 2007, 17:45:48 »
before yes..But now I see expensive rain tyres change the design..Not V shaped
« Reply #11 on: 05 October 2007, 18:44:28 »
In ultra performance wet tyres (ie track use) they tend to go for small 'blocks' of rubber, as the stresses aid warmth, hence grip
« Reply #12 on: 05 October 2007, 19:11:54 »
Yep..also longitudinal channels are wider and deeper..
Dazzler
  • Haverhill, Suffolk
« Reply #13 on: 05 October 2007, 20:05:40 »
I must agree, my LC Rep with its 265 rears steps out at the slightest blip on the throttle ;D
STMO123
« Reply #14 on: 05 October 2007, 21:24:48 »
Keep your filthy sex life to yourself, pervert  :D
