Author Topic: Strange fault messages  (Read 1327 times)
B.L.U.E
  • Portsmouth
« on: 28 December 2007, 22:38:11 »
 Hi everyone merry xmas belatedly, just before xmas i was driving my 2.5 auto elite 2000 (W) saloon. i kicked down, it felt like it went down a couple of gears then the TC light came on, also briefly the dreaded engine management light appeared (it went out as i eased off the throttle) then the computer displayed automatic gearbox CHECK. both the TC and gearbox etc stayed on, it lacked power and was stuck in 3rd or D, until i restarted it later when all fault lights were off. and it drove ok changing gear again etc. later i booted it again to see if it would re-occur (it did), this time the TC came on and the automatic gearbox CHECK also, and both stayed on. don't know if its related but the revs sometimes were sticking between 2000/2500 rpm. the garage said there were too many fault codes to know which was the problem, one of them was the accelerator position sensor. they cleared the fault codes and said they could not get it to do what happened to me. can anyone help please??
« Last Edit: 28 December 2007, 22:40:56 by B.L.U.E »
Jay w
  • Plymouth/Poole
  • omega gone
Re: Strange fault messages
« Reply #1 on: 28 December 2007, 22:57:41 »
hi BLUE, welcome to the forum,
Could be a couple of thing that were causing the issues with the gearbox, one is the selector switch, mine does it every now and again, the other is the gearbox fluid may require changing, i read somewhere it should be changed every 60k miles
B.L.U.E
  • Portsmouth
« Reply #2 on: 28 December 2007, 23:05:29 »
Thanks, had the fluid changed about 4k ago. these fault codes all happened at the same time, just as i used the kickdown to get past a volvo battlewagon (old square shaped estate). and its not doing it since i collected it from the dealers yesterday.
« Reply #3 on: 28 December 2007, 23:12:17 »
....... one of them was the accelerator position sensor........
That's where I'd start then. If your gearbox doesn't know what the throttle is doing, then it will throw up a fault cos it won't know when to change. Unplug it and see.
B.L.U.E
  • Portsmouth
« Reply #4 on: 28 December 2007, 23:18:21 »
i was thinking the same, the garage was reluctant to start fitting new parts unless they were certain of curing it (good for a dealer). how do i disconnect it, and what am i looking for to happen. cheers
« Reply #5 on: 28 December 2007, 23:24:47 »
http://www.omegaowners.com/forum/YaBB.pl?num=1189893355
It's not actually labelled but it's at the end of the throttle cable of the top picture - bottom picture is of the 2.6/3.2 engine which is drive-by-wire and so doesn't have a throttle cable but there is a red box wherethe switch is. There's an ordinary plug on it!  :y
I mentioned unplugging the Throttle Positioning Switch just to prove the point that it will thow up the fault you mentioned. You'll have to manually select the lower gears & you'll lose 4th gear.
B.L.U.E
  • Portsmouth
« Reply #6 on: 28 December 2007, 23:29:02 »
thanks alot won't go and look now, apart from being dark and cold the fridge is still full of beer!!!
