Author Topic: Welding  (Read 4749 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Welding
« on: 05 October 2007, 23:18:07 »
Anyone got any tips for the novice arc welder?
Just bought one of those cheapo welders from aldi in the hope of me and Tonygnome learning how to, so tips from those more experienced would be great.
TuBy's new whipping boy.
Re: Welding
« Reply #1 on: 05 October 2007, 23:20:04 »
hotel21
  • The Kingdom of Fife
Re: Welding
« Reply #2 on: 05 October 2007, 23:22:45 »
Practice, practice and practice some more, before lunching onto something important.  Listen for the real fizzle of a good penatrative weld, sounds like a good crispy bacon slice in the pan and without breaks....  Dont over power the thing so as to get burn through and try upright welding once you are happy on the flat.  Slice a few practice runs open to see whats inside the weld....
Is it stick or MIG?  If stick, you know you have a tidy weld if you can clear the slag off as one nice strip.  if it takes lots of chipping then its like badly chewed chewing gum and no great penetration.....
If MiG, with practice, you can weld rust!!   ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Welding
« Reply #3 on: 05 October 2007, 23:29:03 »
Tis a stick Broocie, £37 from that famous discount tool emporium Aldi, 40-160 turbo jobbie.
Just bought it to play really, as we discussed at Newent I've played with gas a bit but never really touched leccy. Will be a learning experience for me and T. Have to blag a load of scrap to play with now.
Re: Welding
« Reply #4 on: 05 October 2007, 23:33:08 »
I have a tractor on my drive ;D
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: Welding
« Reply #5 on: 05 October 2007, 23:43:24 »
I borrowed a MIG from work to fix my BBQ. I can only agree with Hotel21, it just takes loads of practice. Never tried with a stick welder but I believe it's quite different. I assume that you can still change the power to the arc?
After a while, you just seem to know when the weld is flowing right. Can't wait to have another go. I keep bugging our engineer at work to let me loose on something but I haven't persuaded him yet.  ;D
[size=24]        [/size][/b]
Re: Welding
« Reply #6 on: 06 October 2007, 00:00:02 »
Just don't repair your stainless exhaust, wondering why you're making a sh!te job of it, and, only when putting the final few blobs of weld on the internal baffle to hold it on, realise that you've got no shielding gas coming out :-[
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Welding
« Reply #7 on: 06 October 2007, 09:49:22 »
After your last  quality exhaust repair Captain i think you have nothing to worry about  ::)
Re: Welding
« Reply #8 on: 06 October 2007, 10:12:13 »
Arc is a bit of a pain....the power figures quoted are miss leading to as you cant get much more than 130 amps from a 13A feed.
Get some old bits and practice, with arc you have to scratch the surface to get it to strike, MIG is better all round for this.
Make sure the metal you want to weld is clean.
And have a good go....its not to hard.
I also got an auto darkening helmet which REALY helps....
Re: Welding
« Reply #9 on: 06 October 2007, 12:30:46 »
Any recommendations? I think this has to be my next welding related purchase. I'm convinced it'd be easier if I wasn't trying to do it one-handed while holding a  mask to my face.
Re: Welding
« Reply #10 on: 06 October 2007, 12:35:32 »
I got one like this (not the same) from ebay.....and its VERY good.
http://cgi.ebay.co.uk/auto-darkening-welding-helmet-mask-Price-includes-VAT_W0QQitemZ200159063932QQihZ010QQcategoryZ67052QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I went for a battery one rather than a solar powered job and a shade rage of 7-13 to give a little better flexability.
Re: Welding
« Reply #11 on: 06 October 2007, 12:37:08 »
Thanks, Mark  :y
Tony H
  • liverpool
  • Black Elites are luurvley
Re: Welding
« Reply #12 on: 06 October 2007, 14:28:04 »
Theres not that many applications that you can use an arc welder on car body work for they are just to powerful and tend to blow thin panel type metal away. If you use any electrical welder on a car remember to disconnect the battery and alternator or it will stuff the diode pack. As said its just practice,practice, practice and eventually you will be able to weld tissue paper :y
platty
  • Cambridge
    • BMW 530d Sport
Re: Welding
« Reply #13 on: 06 October 2007, 15:32:40 »
With it being a stick welder, i would make sure the rods you get are half decent, cheapo ones are ok on heavy work but when you want to be more delicate they aren't very good.
As everyone else says practice lots, and its better if you have a fancy mask whereby you can use both hands, and are using clean metal!! Its much harder welding on scrap than decent stuff. Well thats my opinion anyhow!
Ken T
  • Stockport
Re: Welding
« Reply #14 on: 06 October 2007, 23:59:05 »
Some thoughts on Arc Welding, or MMA (Manual Metal Arc) as its now called. The hand held masks are a bit of a pain, you really need 2 hands to control the  torch and your work. Machinery Mart have a selection of flip down masks under £10, and they usually come right down so cover part of your chest, which is very useful. Its a pain if you get a red hot spark of molten metal down your teeshirt, you can't get the B*** out, and it still burns, oh yes!!  ;D.  Next thing is a good pair of Welders Leather Gauntlets. They don't cost a lot (£3?) but protect your hands, sleeves from sparks. They last a long time, mine are over 15 years old, so are a good investment. I also spashed out on a leather Bolero, which also covers my arms and chest, which is very useful if you are welding overheard. There is something pyschological about welding overhead watching the shower of sparks fall down, thinking  "SH1T, these are all at 1100deg C, and may get down my teeshirt" !!  :-? :-? :-?.  The autodarkening helmets are very clever, but you may end up spending twice what the welder cost for safety equipment, which you may rarely use. Try a cheap flipdown, and if you want to progress get an auto darkening. The hand held mask is still useful, someone will invariably want to watch the pretty sparks. This is a BAD IDEA, arc welding gives off intense UV, which dries out the cornea, and makes you feel as if someone has put a load of sand in your eye. Not nice. The effect usually wears off after a day, and there shouldn't be any permanent damage but.....
Now onto actual welding. The factors that affect the weld are : current, angle of torch, speed of travel, and clean work.  If you can, get a piece of about 1.6mm steel, and 1.6mm electrodes. I chose  1.6mm steel because its about the optimum thickness for that size of electrode, also about the thinnest you can properly weld with that current. You can sometimes weld thinner, but its a bit difficult.  Clip the earth electrode to the steel, clip an electrode in the torch, and set the welder to about 40A. Angle the electrode at about 45deg, and scratch it across the surface of the steel. This should start an arc. Remember not to stop, or the electrode will weld itself to the steel, and you will have to switch off or unclip the electrode and bend it to get it off. This will damage part of the flux covering, so the electrode will be a pain to use next time, it will tend to stick immediately. Keep trying this, and eventually you will get a good bead of weld on the surface. Once you have chipped off the slag look at the bead. It should be nice and even, between 1 and 2mm high. If much higher than this, you are not getting good penetration to the steel, so the current is a bit low, you are too slow, the angle is a bit high, or the surface dirty. Also as said by Hotel21, the slag should chip off easily. The idea is that the slag solidifies on the surface of the molten metal and protects it from oxidising when it is cooling. If it get mixed up in the weld metal, then the arc is jumping about, speed is slow, or the angle is too high. Having got this sussed, try increasing the current to say 80A and trying the same again. This is your doubling the heat input, the arc will sound much fiercer, the metal should start to glow red, and its poss you will blow a hole. Thats OK,  try welding at a faster speed and see how it affects things. Thats the rule, if welding thin metal keep the current down, but watch out for incomplete penetration. If thick, turn it up, 'cause a lot of heat will be ducted away by the metal thickness.
Now try welding 2 pieces of steel together. put them apart about 1mm,  and weld short blobs every 4 ins to keep them spaced that distance. When you weld, the heat will make the metal tend to bend away, so the gap may start at 1mm, but will soon become 2 or 3 or 4mm which will be a pain!. Using the 40A setting, start an arc at the top, still 45deg to the direction of travel, and weld down the job. When finished, chip off the slag and look at the weld from both sides. Ideally you should have a bead about 2mm high on top and about 0.5mm on the bottom, and there should be no sign of the metal edges underneath. This means that you have totally penetrated the thickness of the metal, and its well fused.
Sometimes you will do a brilliant weld and immediately pick it up to show someone how good you are. THIS IS NOT  A GOOD IDEA. The metal has recently been at about 1100deg C, and will still be hot to the mortal hand for a long time.  That is reason why the welding guantlets are a GOOD IDEA !. They are also handy, when welding thick metal (>6mm), I tend to use the left gloved hand to guide the electrode near the work. Try writing with a pencil 12" long, held from the blunt end.
The Nirvana of Arc Welding is when you finish a weld, flip the helmet up, you hear a slight crack from the cooling metal, and the slag curls off all by its self. This only happens rarely, but when it does, it means you have got all the parameters right, the slag has hardened and is protecting the steel, which is cooling and shrinking, and hence the flux peels off all by itself. I've only had it happen a few times, but its very satisfying when it does !!!!.  :y :y :y
Best of luck
Ken
« Last Edit: 07 October 2007, 00:08:34 by Ken_T »
