Author Topic: Fault codes  (Read 4079 times)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Fault codes
« Reply #15 on: 24 December 2007, 11:16:38 »
I bought one of these and it works fine on my 2.2 facelift..........read the codes and cleared them no trouble  :y
http://cgi.ebay.co.uk/GS400-Pro-OBD-2-Scanner-Diagnostic-Trouble-Code-Reader_W0QQitemZ300183553356QQihZ020QQcategoryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Trade club card holder
Code scanner available
Re: Fault codes
« Reply #16 on: 24 December 2007, 11:42:26 »
2.2 (and 2.6/3.2) is OBDII compliant, so generic OBDII readers will read the engine (only)
    • E250 Est / Elroq
Re: Fault codes
« Reply #17 on: 24 December 2007, 13:21:47 »
IF your lucky, I borrowed one and it couldnt read our 2000 2.2  :(
jules
  • Edinburgh
  • Woke up this morning a post whore
Re: Fault codes
« Reply #18 on: 02 January 2008, 20:34:16 »
Update as promised :
This kit, as supplied can interrogate the 1999 ECU for data like vin etc. It does not read fault codes or do much else. It does not work with the hurdy gurdy software.
However it works fine with our 2001 scenic, allowing code reads and resets as well as real time data monitoring. I also used it to reset the airbag light on the outlaws fiesta (53)
I also bought the same sellers 'Tech 2' which I am awaiting delivery of.
Cheers
Jules
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
Re: Fault codes
« Reply #19 on: 02 January 2008, 20:51:18 »
Cheers
Jules
As expected.
The Tech2 will 'work' (the software can be troublesome) if you have a real com port....
