indicator stalks do not cancel after turns
Started by dpanic88, 01 January 2008, 18:11:55
dpanic88
Just changes stalks to enable cruise control, which works a treat - no extra bits required. Car already has clutch and break switches - on 2.2 dti cdx.
After change new stalks do not travel very far when you indicate left or right - plus they do not cancel when stearing wheel comes nack to normal.
Question; anyone had this? Or are they not fitted correctly. Might take the outer cover from stearing column off to see.
jonathanh
they should cancel as before.  was it a new stalk or second hand because the cancel function does wear out.  Also chek the fitting as the cancellation relies a level being activated by the steering column.
dpanic88
They were sold as new on ebay ( sealed package, they also look new ). I'll remove and reseat then tomorrow. Is the level bit a switch or a manual part on the column or wheel?
Could be that the stalk is not pushed fully home in the clip that secures it.
Also, have a look when it's off. There's a small plastic tab in the base of the switch that gets flicked by the steering column to cancel the indicators. Check it's free to move and not broken off.
dpanic88
Cheers chaps, will have a look tomorrow and report back.
dpanic88
dpanic88
re:There's a small plastic tab in the base of the switch that gets flicked by the steering column'
When I fitted the first time - the plastic tab was stuck in - after a redo - all is well - many thanks
markey mark
