Author Topic: Stripped sump plug thread  (Read 5147 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 05 January 2008, 19:01:22 »
My 2.5td (BMW engine) has a stripped sump plug thread. (Last serviced by Vauxhall!) It has an M12 x 1.5 plug. Has anyone replaced this with an oversize, and if so which size.
Thanks
Re: Stripped sump plug thread
« Reply #1 on: 05 January 2008, 19:30:22 »
Methinks JamesV6 is the expert in this field ... I'm sure he'll answer you with EXACT instructions very shortly ...
« Reply #2 on: 05 January 2008, 19:53:04 »
Thanks
Yeah, stripped 3 of the buggers  >:(
« Reply #3 on: 05 January 2008, 19:54:58 »
Forgot to say, I plan to Helicoil mine for a stronger thread.
Thats a lie, I'm going to get Mr DTM to helicoil mine, while I drink tea and eat choccie biccies that Mrs DTM will poshly arrange on a nice china plate....   ::)
Shackeng
  • Ramsbury
« Reply #4 on: 07 January 2008, 19:31:30 »
OK Guys, I just drilled it out and tapped it to take an M14 x1.5 plug, only an hour's job with the oil change, and the larger plug will make it less likely to strip in future. Incidentally I used a 12mm drill rather than the recommended 12.5mm, and it was the ideal size in ally, probably 12.5mm would be OK in steel.
On this subject, I rather like the look of the Femco replacement sump plugs, with an integral drain, especially for ally sumps. Has anyone any experience of them?
Cheers
« Reply #5 on: 07 January 2008, 20:20:48 »
Cheers
I still stripped mine after retapping. And I used a torque wrench (set to 25Nm).
I will be trying those quick drain ones when I next change oil...
« Reply #6 on: 07 January 2008, 20:23:47 »
Hmm. They look interesting.
I wonder if one could be fitted to each gearbox sump too?
osealy
  • dublin
« Reply #7 on: 07 January 2008, 21:21:21 »
fitted a femco to last td. (not the low profile one). Took the whole thing out over a country yump. was looking at the idiot lights afterwards & stopped a soon as light came on. motor ok after.
If your current plug is still in , I suggest pila oil pump, suck out thru dipstick, c60 Euro, job done while changing filter, no grovelling needed.
« Reply #8 on: 07 January 2008, 21:25:04 »
Did wonder the problem with it being low.  Never had any faith in sucking oil out....
May just have to put the undertray back on for protection...
« Reply #9 on: 07 January 2008, 21:25:04 »
 :o
Maybe not then.
I'm still tempted for the Westfield and MX5 because it's a pain to get under them and the plugs are both on the side of the sump.
N2STY
  • RICKMANSWORTH
« Reply #10 on: 07 January 2008, 21:27:51 »
i had to use one of these on smart cars as they have no sump plug they work well
osealy
  • dublin
« Reply #11 on: 07 January 2008, 22:37:17 »
I originally bought for my ski boat. Most marine engines use pump out & are expected to last forever. However with 4.5k oil changes it's a godsend. 22.5k this year.
Shackeng
  • Ramsbury
« Reply #12 on: 07 January 2008, 22:48:24 »
Why is everyone talking about 4.5k oil change? my '99 td (BMW engine) is DEFINITELY 7,500, and I'm told they go much longer in the BMW chassis, with a warning to advise that oil change is due depending on condition. I suspect the shorter interval is for different engines. I like the sound of pumping out with the Pila, how much? £40?
Cheers
« Reply #13 on: 07 January 2008, 22:49:23 »
I can't find any reference to "Pila oil Pump" on the web .. do you have more details ?
osealy
  • dublin
« Reply #14 on: 07 January 2008, 22:56:48 »
  Pela Oil Extractors (2000) at Cabela's  .
I had the same prob finding them. They're widely availabable from marine suppliers, gotta go.
