Author Topic: Omega 2.2 Cruise Control  (Read 1898 times)
Davey
  • Berkshire
« on: 09 January 2008, 12:55:44 »
I've just bought a 2001 2.2 Auto CD with the later fly-by-wire management..
Would I be correct in saying if I get a cruise stalk and the brake switch the cruise control should work?
Cheers!
    • E250 Est / Elroq
Re: Omega 2.2 Cruise Control
« Reply #1 on: 09 January 2008, 12:58:44 »
Almost.....Will also need tech2 to 'turn it on'
Davey
  • Berkshire
« Reply #2 on: 09 January 2008, 13:20:12 »
Cheers!
Will have to ask my mate nicely if he can sort it for me :)
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« Reply #3 on: 09 January 2008, 16:21:07 »
I don't think you would need a brake switch. Mine didn't and I haven't seen any on here that did.  :y
[size=24]        [/size][/b]
Davey
  • Berkshire
« Reply #4 on: 09 January 2008, 16:23:53 »
Even better!
« Last Edit: 09 January 2008, 16:35:42 by Davey »
« Reply #5 on: 09 January 2008, 16:26:27 »
Yep....every time I have seen a drive by wire one and enabled cruise, the brake switch has not needed changing.......easy to check using live data and tech 2.
« Reply #6 on: 09 January 2008, 20:52:54 »
wont need brake switch, may need clutch switch if manual.
If you haven't got access to real Tech2, see http://theboy.omegaowners.com
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #7 on: 10 January 2008, 12:57:29 »
 just plug and play with the dti 10£ from the breakers and off i went
dieseldonicely
« Reply #8 on: 10 January 2008, 19:06:25 »
diesel omegas normally preenabled
