Anti Freeze tester
Started by Big_Roger, 17 January 2008, 21:48:07
Big_Roger
Hi all,
Does any one know if the simple anti freeze tester (Halfords) is accurate with the VX Red Long life anti freeze.
It says only Ethylene Glycol type. As I understand it the VX Red (and other red coloured makes) is Propylene Glycol based anti freeze.
Any info ?
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
No it wont give a good reading.
The best method realy is to drain the coolant, flush the system with clean water and re-fill with the correct anti freeze mix
Big_Roger
Hi All,
My reason for asking was that yes I have drained and flushed system, and added 4 L of VX Red, so was happy all was OK.
It was only out of idle curiosity that I tried with the tester, which happened to be in my toolbox, and was surprised that only two balls floated saying more a/freeze was required.
Hence query on accuracy with propylene glycol mixtures.
Roger
