Mass airflow meter??
Started by arthill, 09 January 2008, 19:16:46
arthill
 Still having problems with car, lossing power under load replaced cam sensor but left with fuel trim (lean ) as the only fault left, mechanic done live diagnostic test while fault was present on lambda sensors, said sensor after cat showed fluctuation where it should be constant. However after stopping and restarting engine fault code  was not present and lambda sensor was reacting as it should ie. constant, he suspects MAF , could this be the answer? any thoughts thanks.  :-/
John
John
Mass Air Flowmeters dont fail easily..
Only loose little performance with time as its a chemical surface..
In your case the reason also can be a combination..
Whats the mileage..
If you rev it does it have any limitation..
Didi you service normal items including air filter,fuel filter,sparks,oil etc
arthill
car recently had fuel filter, spark plugs, oil change, no limitation on revs except when this intermittant fault occurs, then it is as if something stopping accelerater and has to be forced to get response,
but stop car switch off and back on and car is fine again ???
 John
John
Hmmmm....it realy needs a good diagnostic tool to look at the live data to confirm.
arthill
Going back in to garage today, had emissions tested at mechanics suggestion, read out showed the lambda part was high, but h is not convinced it is lambda sensor, could those symptoms be caused by MAF sensor,
John
John
QuoteGoing back in to garage today, had emissions tested at mechanics suggestion, read out showed the lambda part was high, but h is not convinced it is lambda sensor, could those symptoms be caused by MAF sensor,
John
In my view no.....as the lambda would correct the mixture to compensate so I suspect the emissions readings are a red herring.
The lack of acceleration and sudden low power could be the MAF but again, it needs checking with live values.
A proper diag session should monitor the airflow with respect to throttle changes etc....I would also be looking at the coolant temp readings as well.
arthill
John
arthill
Hi
Had car in garage today to check MAF. voltage checked at idle voltage read .6 mechanic said reading expected was 1.1,   when revved reading was 3.2 as expected.  after disconnectng and re-connecting Maf MIL went out , can I assume therefore that this is part of my problem.
 John
John
QuoteHi
 John
No you cant.....it could read 0.6 at idle if there is an airleak...hence why he should have done further tests and actuator tests.
The fact that it is tracking throttle sudgest the opposite and that it is good.
The fact that disconnecting and re-connecting MAF tends to sudgest more of a wiring fault or poor connection....but then again it could be a red herring.
arthill
Thanks Mark
Going back in next week, will be discussing your comments with him, and report back here. thanks again.
 John
John
Just an idea check the injectors connector socket behind the plenum..
Take the socket and wash with wd40 or with a rust solver spray and
plug it back..Mine did something similiar and become a headache
once..
And a cheap advice ..Change the o-rings around the inlet manifold..If
they are old they become tiny and leak air..
May be these will not solve your problem but will prevent extras in the
future..
arthill
 Reporting back as I said, back to garage on wednesday, fitted new maf and all fault codes disappeared, took car for run and it seemed fine, I've been working all week so car had been parked until this afternoon, although lying that time and the cold weather it started straight away with immediate response from accelerator drove to the places I had problems before puting car under load and everything was fine and so far there has been no problems. Hopefuly this is the end of a long saga. ;) :) :) Thanks again for all your help.
John
ps. bought maf from partsdome on ebay £32.95 :y
John
QuoteReporting back as I said, back to garage on wednesday, fitted new maf and all fault codes disappeared, took car for run and it seemed fine, I've been working all week so car had been parked until this afternoon, although lying that time and the cold weather it started straight away with immediate response from accelerator drove to the places I had problems before puting car under load and everything was fine and so far there has been no problems. Hopefuly this is the end of a long saga. ;) :) :) Thanks again for all your help.
John
Interesting, I have only ever seen MAFs fail on 2.2 petrols and the odd 2.5TD......
arthill
John
